7.1
2013-01-30
Modify Pricing and Ordering parameters
In the Pricing and Ordering section of a company or department a tax rate profile can be selected. The calculation of shipping rates can be enabled and a payment module can be selected. In addition to this it defines the shipping rate profiles visible in the order working. If multiple profiles are available the end user can select the preferred method. The calculation of shipping rates has the following prerequisites:
To set the pricing and ordering settings for a company:
  1. Click Companies in the Menu bar. The Companiesoverview page is shown.
  2. Click Pricing and Ordering in the side menu, the Pricing and Ordering Settings page appears.
  3. Click Edit. The Pricing and Ordering Settings screen appears:
  4. This page contains the following sections and lets you set the following items:
    • Tax: Defines the Tax Rate Profile that applies to this company (or department).
    • Shipping Rates: This section defines the following shipping charge options:
      • Calculate Shipping Charges: Check the Calculate Shipping Charges checkbox to enable the calculation of shipping rates for this company (or department). This enables the options below.
      • Use System Defaults: If selected the system default rates are used in the ordering workflow. If this option is selected the Shipping Rate Profile area is enabled.
      • Shipping Rate Profiles: The shipping rate profiles become available when the Use System Default checkbox is unchecked. To select one or multiple contiguous profiles use shift click. Non contiguous items can be selected with alt click.
        When multiple shipping rate profiles are assigned, the customer is able to select the preferred shipping method in the ordering workflow.
        Shipping charges can be defined for the company and/or departments. These are managed independently; the profile list of a department can be completely different from the list for the company (e.g. when located in a different country or region).
    • Payment Modules: This section controls the settings used for the payment modules.
      • Use System Defaults: If selected the system default module is used. If this option is deselected the Module area becomes available.
      • Modules: The modules become available when the Use System Default checkbox is unchecked. To select one or multiple contiguous modules use shift click. Non contiguous items can be selected with alt click.
        When multiple modules are assigned, the customer is able to select the preferred payment method in the ordering workflow.
        Modules can be defined for the company and/or departments. These are managed independently; the module list of a department can be different from the list for the company (e.g. when located in a different country or region).
  5. Click Save to store the changes.
