7.1
2013-01-30
Test mode
You can also request a developer test account from Moneris to make test payments.
The developer test account is actually a shared account that is used by all the people who are currently testing their web shop against the Moneris test gateway. Therefore you should not make any changes in the test account settings. You can also see other transactions that where not generated by yourself.
Moneris has provided several documents on their website which describe how the testing process goes. The shop owner should download the following documents from http://www.eselectplus.ca/en/downloadable-content if the shop owner doesn't have access to this part of the site he must sign up before he can download the documents.
The following documents should be downloaded:
The test environment of Moneris uses shared test accounts. In the PHP API Integration Guide on page 21 there is a list of several test accounts that can be used. If you want to test CVD or AVS you must use store5. In the same document on page 22 there is al list of credit card numbers that can be used in the test environment.
In the payment connector settings on the PSMW website you must enter the store id and api token of a test account and set the gateway to test before you can make any test payments.
The penny value will determine if the payment will be successful in the test environment please read the Test Environment Penny Value Response Table document for more details.
The AVS and CVD checks are additional; this means that those checks could fail but you could still have a successful transaction, if that happens PSMW will perform a void action on the payment to cancel it. The AVS or CVD check will only be performed if you have enabled them in the payment connector's settings page.
In the settings page you can also select which AVS and CVD response code you want to accept. If the transaction was successful PSMW will do an additional check by looking at the AVS and CVD response code. If the response code is not accepted according to the payment module settings PSMW will do a void action to cancel the transaction, that void action is than visible in the moneris account website.
To manage your Moneris account you will have to go to the Moneris developer merchant account website: https://esqa.moneris.com/mpg/
