7.1
2013-01-30
Settings
In the Settings window from the Pricing and Ordering section you can define several general system settings. The Pricing and Ordering Settings pages contains the following sections:
To change the general Pricing and Ordering Settings:
  1. Click Settings in the Menu bar.
  2. Click Settings in the Pricing and Ordering section from the side menu.
  3. Click the Edit button. The following screen appears:
    The general Pricing and Ordering page
  4. The Pricing and Ordering window contains the following options:
    • General:
      • Currency: The selected currency will be presented in Checkout and Order Manager sections of the system.
      • Weight Unit: The weight unit is used to define the total weight of the documents/jobs in the checkout. PrintShop Mail Web supports kg and lb.
      • Tax: The standard Taxation system. The exact parameters of the selected Taxation system can be modified in the Tax Rates section. A Tax Rate system can be specified per company/department or template. If no Tax Rate system is defined at these levels, PrintShop Mail Web system will use the one specified in this section (the system default).
    • Payment Connector:
    • MIS Connector: The MIS Connector section lets the administrator activate a MIS Connector. MIS Connectors are used to send order information to external MIS systems on order creation or order status changes. The communication method and the type of data used to exchange information depends on the selected MIS connector and is often determined by the developer of the MIS system.
    • Costs: In the Costs section defaults can be defined for:
      • Setup Costs: A surcharge for setting up your production environment and workstations.
      • Rush Rate: A surcharge for urgency printing (if applicable).
      When no costs are specified at template level (Edit Pricing page) the system default costs are used. To specify the Setup costs and Rush Rate on a per template basis see Add publication types.
  5. Click Save to store the changes.
