The New Document tab is used as part of the Ordering process, and is the first step in creating and completing an order. It is used to select a document to order from a list of documents in publication types, and will only display documents that are active and related to the company you are logged on under.
To get to the New Document tab:
Once you are within the New Document tab, you will see a list of publication types that are available for you to order.
When you click on a publication type in the New Document tab, two things can happen. If the publication type contains more than one document, you will be sent to the Document Selection Screen. If there is only one document in the publication type, you will be sent to one of the following windows:
