7.1
2013-01-30
Receiving Jobs from Print to Web
PrintShop Mail Web, on top of being a Web-To-Print solution, is also a print server that can receive jobs from any PrintShop Mail Design software whether this installation is local or remote. However, there are a few specific points that must be handled for this integration between Design and Web to be functional.
Once the setup is done properly, you can use the Print to Web feature from PrintShop Mail Design. The Print to Web dialog will display the URL of the PrintShop Mail Web server, a list of companies on that server and the printers that are installed and activated on the server. PrintShop Mail Design will send the job to PrintShop Mail Web for processing.
When using Print to Web, you can change the print technology to correspond to the printer you are outputting to. If you select Adobe PDF or PDF/VT-1 technology, however, the job will not output to a printer, obviously. Instead, the PDF file will be available in the Print Jobs, accessible through the Order Manager.
