Installation Wizard
Updating to Connect 2019.1 from earlier Connect version
In order to update PrintShop Mail Connect to 2019.1 it is first necessary to update the Connect License.For details on how to upgrade the Connect License see Users of Connect prior to 2019.1
Starting the PrintShop Mail Connect installer
The PrintShop Mail Connect installer may be supplied as an ISO image or on a DVD.
If an ISO image, you can choose between the following, depending upon your Operating System and the choices available:
Burn the ISO image onto a DVD
Un-zip the contents to a folder (keeping the internal folder structure intact)
Mount the ISO image from within Windows Explorer
If on a DVD, either insert the DVD and initiate the installation from there or copy the contents to a folder on the target computer (keeping the folder structure intact)
Navigate to the PrintShop Mail_Connect_Setup_x64.exe and double-click on it. After a short pause the Setup Wizard will appear as a guide through the installation steps.
Note that PrintShop Mail Connect requires prior installation of Microsoft .NET Framework 4.5. For a full list of other prerequisites, see Installation Prerequisites.
Running the Installation with extra logging
The installer can be run with enhanced logging options, if needed.
To do so, run the PrintShop Mail_Connect_Setup_x64.exe from the command line with one of the following command line options:
PrintShop Mail_Connect_Setup_x64.exe --verboseThis adds extra debugging style logging to the installation process.
PrintShop Mail_Connect_Setup_x64.exe --traceThis adds full trace style logging to the installation process. The log file this produces will be very large, as this option logs everything.
Selecting the required components
After clicking the Next button, the component selection page appears, where the different components of PrintShop Mail Connect can be selected for installation. Currently, the following are available:
PrintShop Mail Connect Designer: The Designer module (see The Designer) can be installed standalone (with no other installed modules) on as many machines as you like. It does not require a license to run as a standalone designer tool . This allows for any number of people to use the Designer for creating jobs, but without production capabilities such as automation and commingling.
MySQL:
A supplied MySQL database used by PrintShop Mail Connect.
The database is used for referencing temporary Connect files and for sorting temporarily extracted data, and similar.
A pre-existing MySQL or Microsoft SQL server (referred to as an external database, in this documentation) could be used instead, for the same purposes.
The external database could reside on the same computer or on a separate server.
If you wish to make use of an external database, please make sure the MySQL option is not selected.If you chose not to install the supplied MySQL database, and instead opt to use a pre-existing external database, then you must ensure that your external database is accessible to Connect, yourself.
Objectif Lune Inc. will take no responsibility for database connections to any but the supplied MySQL database.
See Database Considerations for more information about setting up external databases. -
Installation Path: This is the location where modules are to be installed.
To cater for MySQL requirements, the installation path cannot contain any non ASCII characters (such as Asian language Unicode characters). Nor can it contain characters that Windows disallows in filenames (such as '?', ''>' or trailing spaces).
If an invalid character is entered, the Installation Path entry box will turn red and a description of the error will be displayed in the information area.
The installer can also calculate how much disk space is required for installing the selected components as well as how much space is available:
Disk space required: Displays the amount of space required on the disk by the selected components.
Disk space available on drive: Displays the amount of space available for installation on the drive currently in the Installation Path.
Recalculate disk space: Click to re-check available disk space. This is useful if space has been made available for the installation while the installer was open.
Source repository location: Displays the path where the installation files are located. This can be a local drive, installation media, or a network path.
End User License Agreement
The next page displays the End User License Agreement, which needs to be read and accepted before clicking Next.
Configuring Supplied Database Connection
The Default Database Configuration page appears if the supplied MySQL module was selected for installation in the Product Selection screen. It defines the administrative password for the MySQL server as well as which port it uses for communication.
The installer will automatically configure the Connect Server to use the supplied password and port.
MySQL user 'root' Password: Enter the password for the 'root', or administration account, for the MySQL server. The password must be at least 8 characters long and contain at least one of each of the following:
a lower case character (a, b, c ... )
an upper case character (A, B, C ...)
a numeric digit (1, 2, 3 ...)
a punctuation character (@, $, ~ ...)
For example: "This1s@K"
When updating from an earlier Connect version, the appropriate MySQL password must be entered or the update will fail.
If the password is subsequently forgotten, then MySQL must be uninstalled and its database deleted from disk before attempting to reinstall.
Confirm MySQL user 'root' Password: Re-enter to confirm the password. Both passwords must match for installation to continue.
TCP/IP Port Number: The port on which MySQL will expect, and respond to, requests. A check is run to confirm whether the specified TCP\IP Port Number is available on the local machine. If it is already being used by another service (generally, an existing MySQL installation), the number is highlighted in red and a warning message is displayed at the top of the dialog.
The MySQL database controlled by the OLConnect_MySQL service communicates through port 3306 by default.
Click Next to display the Selection Confirmation page.
This page confirms the installation selections made.
Click Next to start the installation itself. This process can take several minutes.
Completing the installation
This screen describes a summary of the components that have been installed.
Configure Update Check checkbox: This option is enabled by default. It causes the Product Update Manager to run after the installation is complete. This allows configuring PrintShop Mail Connect to regularly check for entitled updates.
Note: this checkbox may not be available in the event that an issue was encountered during the installation. -
Show Log...: If an issue was encountered during the installation, click this button to obtain details. This information can then be provided to Objectif Lune for troubleshooting.
When ready, click the Finish button to close the installation wizard, and initialize the Product Update Manager, if it was selected.
The Product Update Manager
If the Configure Update Check option has been selected, a message will be displayed after clicking “Finish” in the setup. The message details the information that needs to be sent back to Objectif Lune Inc. in order to determine when/if the software needs updating.
Click “Yes” to install or open the Product Update Manager where the frequency with which the updates can be checked and a proxy server (if required) can be specified.
Select the desired options and then click OK to query the server and obtain a list of any updates that are available for your software.
Note that the Product Update Manager can also be called from the “Objectif Lune Update Client” option in the Start menu.
It can be uninstalled via Control Panel | Programs | Programs and Features.
Product Activation
After installation, it is necessary to activate the software. See Activating your license for more information.
Before activating the software, please wait 5 minutes for the database to initialize. If the software is activated and the services rebooted too quickly, the database can become corrupted and require a re-installation.
