Package dialog
The Package dialog saves templates and Print Presets as a package file. Package files can be sent to other Connect Designer users.
- Configurations: Initially this list contains the Connect files that are currently open.
- Browse: This button opens the Select Files dialog that lets you add one or more templates (*.OL-template) and Print Presets (*.OL-jobpreset, *.OL-outputpreset) to the list.
- Select Preset: Opens the Select Preset dialog. This dialog lists all Print Presets found in the folder:
<root>\Users\<username>\Connect\workspace\configurations. There are two ways to make it easier to find the file that you need:- The Show drop-down list lets you select the type of preset that you want to open.
- In the Filter field, you can enter (part of) a preset name to filter the list for matching presets.
- Delete: Deletes the selected file from the list of configurations.
- Package...: This button opens the Save dialog. All selected Connect files will be saved to one package file. You can use the topmost checkbox to select all of the listed files at once.
- Cancel: Click this button to close the dialog without creating a package file.
