GS1 DataMatrix
GS1 DataMatrix is one of the types of barcodes that can be added to a template; see Barcode.
Initially the barcode will have the barcode type's default properties. To change those properties, such as the scale and color, open the Barcode properties dialog: right-click the barcode (on the Design tab in the Workspace) and select the barcode type on the shortcut menu.
About GS1 DataMatrix barcode data
In order to create a GS1 compliant DataMatrix barcode, the barcode data must meet the following requirements.
- The barcode data must start with a leading FNC1 character:
~1. When this function code is omitted the barcode may be scanned as a DataMatrix barcode instead of a GS1 DataMatrix barcode. - The GS1 Application Identifiers (AI) must be used for all data. In addition, the function code
~1must be used as field separator for variable length AI elements. - Only ASCII characters should be used.
Barcode properties
This topic lists the properties of the barcode type GS1 DataMatrix. For the properties of other barcode types, see Barcode type and properties.
Module width
Preferred format
Use the drop-down to select the size of the Data Matrix.
Scale
- None: The barcode is rendered based on the module width.
- Fit to box: The barcode is stretched to fit the parent box in both width and height.
Add Checksum
When checked, PrintShop Mail Connect will calculate a Checksum character and add that to the result of the Barcode script. If the value to be encoded is longer than 10 digits, a second check character will be calculated.
Tilde processing
Check this option to process tilde characters in the data as special characters. (See the Java4less Barcodes Guide to learn what the tilde character can be used for.)
Human Readable Message
When this option is checked, PrintShop Mail Connect shows a human readable text below or above the barcode, as defined using the Text Position, using the specified font and font size. The font size is given in points (pt).
Color
Output format
- SVG: Vector format. This is smaller in size, but not compatible with Email output.
- PNG: Binary rasterized format. This is slightly larger than SVG but will display properly in Email output.
