Code 39 extended
Code 39 extended is one of the barcode types that can be added to a template.
Barcode properties
This topic lists the properties of the Code 39 extended barcode type. For the properties of other barcode types, see Barcode type and properties.
Module width
Inter Character Gap
Two adjacent characters are separated by an inter-character gap. A value of 1 means that the separator will have the same length as the width of the narrow bars (in centimeters).
Scale
Tilde processing
Add Checksum
When checked, PrintShop Mail Connect will calculate a Checksum character and add that to the result of the Barcode script. If the value to be encoded is longer than 10 digits, a second check character will be calculated.
Tilde processing
Human Readable Message
When this option is checked, PrintShop Mail Connect shows a human readable text below or above the barcode, as defined using the Text Position, using the specified font and font size. The font size is given in points (pt).
Color
Output format
