Code 93 extended
Code 93 extended is one of the barcode types that can be added to a template.
Barcode properties
This topic lists the properties of the Code 93 extended barcode. For the properties of other barcode types, see Barcode type and properties.
Module width
Scale
Add Checksum
When checked, PrintShop Mail Connect will calculate a Checksum character and add that to the result of the Barcode script. If the value to be encoded is longer than 10 digits, a second check character will be calculated.
Tilde processing
Human Readable Message
When this option is checked, PrintShop Mail Connect shows a human readable text below or above the barcode, as defined using the Text Position, using the specified font and font size. The font size is given in points (pt).
Color
Output format
