USPS IMpb
USPS IMpb is one of the barcode types that can be added to a template; see Barcode.
In PrintShop Mail Connect versions prior to 2019.2 this barcode was called "IMPB".
Note that this type of barcode processes tilde characters (~) in the data as special characters. See the Java4less Barcodes Guide to learn what the tilde character can be used for.
Note: Application Identifiers in the barcode value need to be surrounded by round brackets, otherwise the barcode will not be generated correctly.
For example, this value contains both a Postal Code Application Identifier (420) and a Channel Application Identifier 93: 420123459302234567890123456788. It should be written as follows: (420)12345(93)02234567890123456788.
More information about Application Identifiers can be found in the barcode specification here: https://postalpro.usps.com/shipping/impb/BarcodePackageIMSpec
Barcode properties
This topic lists the properties of the USPS IMpb barcode type. For the properties of other barcode types, see Barcode type and properties.
Color
Output format
