Royal Mail 4-State Mailmark C, Royal Mail 4-State Mailmark L
Royal Mail 4-State Mailmark C and Royal Mail 4-State Mailmark L are some of the types of barcodes that can be added to a template; see Barcode.
This topic lists the properties and output options of the barcode types Royal Mail 4-State Mailmark C and Royal Mail 4-State Mailmark L.
For the properties of other barcode types, see Barcode type and properties.
Barcode properties
Height, width and spacing
Bar height: The height of the (shorter) bars.
Extended bar height: The total height of the extended bars.
Bar width: The width of the bars.
Spacing: The distance between the bars.
Scale
Proportional: The barcode is stretched up to where it fits either the width or height of the parent box, whichever requires the less stretching.
Human Readable Message
When this option is checked, PrintShop Mail Connect shows a human readable text below or above the barcode, as defined using the Text Position, using the specified font and font size. The font size is given in points (pt).
Barcode output
Color
Output format
SVG: Vector format. This is usually of higher quality, but may take longer to generate and is not compatible with Email output.
PNG: Binary rasterized format. This has a slightly lower quality than SVG but is usually generated faster and will display properly in Email output.
