UPC-A, UPC-E, EAN-8, EAN-13
UPC-A, UPC-E, EAN-8 and EAN-13 are a few of the barcode types that can be added to a template.
Note that these barcode types process tilde characters in the data as special characters. See the Java4less Barcodes Guide to learn what the tilde character can be used for.
This topic lists the properties and output options of the barcode types UPC-A, UPC-E, EAN-8 and EAN-13. For the properties of other barcode types, see Barcode type and properties.
Barcode properties
Module width
Scale
Fit to box: The barcode is stretched to fit the parent box in both width and height.
Supplement
UPC-A, UPC-E, EAN-13, and EAN-8 may all include an additional barcode to the right of the main barcode.
Type: The supplement type can be 2-digit (originally used to indicate the edition of a magazine or periodical) or 5-digit (used to indicate the suggested retail price for books). In case this option is set to None, and the data includes digits for the 2 or 5 supplement, the supplement data will be skipped and the additional barcode will not be rendered.
Note: When the chosen supplement type doesn't match the data, the supplement data will be skipped and the additional barcode will not be rendered.
Height Factor: This is the relative height of the supplement's bars compared to the normal bars.
Space Before : Defines the space between the main symbol and the supplement, in cm.
Human Readable Message
PrintShop Mail Connect shows a human readable text below the barcode, using the specified font and font size. The font size is given in points (pt).
Barcode output
Color
Output format
SVG: Vector format. This is usually of higher quality, but may take longer to generate and is not compatible with Email output.
PNG: Binary rasterized format. This has a slightly lower quality than SVG but is usually generated faster and will display properly in Email output.
