Add a Metric Value to a Report
In Report Wizard, you are able to create one or more user defined columns that will display metric information.
Note: Metric is a replaceable term in PowerSteering. Your site may be using a different term for this word.
1. Click Report Wizard
Click Report Wizard
  1. On the Icon Bar click the Add button.
  2. Click Report to expand the menu, then click ReportWizard.
2. Select Category and Type
  1. Select a type and category for your report. See Report Wizard Type Tab for more information about this step.
  2. Click Continue.
3. Add Metric Value
Add Metric Value
  1. On the Columns tab, click User defined to expand the section.
  2. From the Column types drop-down menu, select Metric value.
  3. Click the green plus sign.
4. Select Metric
Select Metric
  1. In the Label field, type a name for your user defined column.
  2. From the Metric drop-down menu, select the metric you want to add data from.
5. Select Metric Information
  • Select metric information using the drop-down menus.
  • Note: The options on this screen may appear differently depending on which metric is selected.
6. View Metric Value
View Metric Value
  • View newly created metric value column. Repeat Steps 3 - 5 to add additional metric values to your report if needed.
7. Preview Report
Preview Report
  • Click the Preview hyperlink to preview the report with the newly added metric value columns.
