2026R1.0 - Resolved Issues
Below is a summary of the main issues addressed by this release. Individual customer cases will be updated by the Support team through the portal. Cases will be closed out with customers upon confirmation that the issue has been resolved to your satisfaction.
Note: This page may be updated as new information becomes available.
The resolved issues in this release fall under the following categories:
Financial Review
A bug prevented users from locking Metrics in bulk from the Financial Review page. Attempting to lock Metrics would result in an error message at the top of the screen.
This bug has been fixed; users can once again use the Financial Review page to lock multiple Metrics without causing an error.
Object Types
A bug allowed work items to share duplicate names even when "Prevent Duplicate Names" was selected while editing the Object Type. When this is selected, users should be prevented from creating work items using the Object Type (including those created with a template that uses the Object Type as root work) if they attempt to enter a duplicate name.
This bug has been fixed; new work items cannot be created with duplicate names if "Prevent Duplicate Names" is selected on their Object Types.
Portfolios
A bug prevented users from opening Portfolios from the Portfolios page. Selecting certain Portfolios would result in an error.
This bug has been fixed; users can once again open up and review Portfolios from the Portfolios page.
Resource Review
A bug prevented the new Resource Review page from loading data once certain filters were applied.
This bug has been fixed; applying filters to the Resource Review page will no longer result in load failures.
Templates
A bug prevented users from selecting administrators on Work Templates. While editing the details of a Work Template, the "Administrators" field was missing.
This bug has been fixed; users can once again select Work Template administrators while editing Work Templates.
Upland Analytics
The exchange rate update process caused an error banner to appear due to a failed storage procedure. This was caused by the large volume of data involved with updating exchange rates, which caused the stored procedure to timeout due to recalculating many periods.
This bug has been fixed; the error banner will no longer appear.
Workflow
A bug prevented users from approving Workflows. Attempting to approve certain workflows would cause an internal server error.
This bug has been fixed; users can once again approve PowerSteering Workflows.
