2016 R1 SP15 - Resolved Issues
Below is a summary of the main issues addressed by this release.
1363.12.07.2017.V1.EB
Note: This page could be updated as new information becomes available.
Financials
R&D #: TE-28564 | Ticket #: 173043
  • Fixed an issue with the Financial Calendars wherein the Fiscal Calendar import was failing due to the logged User's Regional Settings date format not having been set to the Import Template's required mm/dd/yyyy format. The applied resolution was to modify the import function to allow for the successful process of the Fiscal Calendar regardless of the logged User's Regional Settings.
Organization Breakdown Structure (OBS)
R&D #: TE-27207 | Ticket #: 167942, 172678, 174158
  • Fixed an issue with Email Templates where Expense Report Rejection Email Notifications were not being sent to recipients set through the Notification Edit page.
Resource Management
R&D #: TE-27348 | Ticket #: 168285
  • Fixed an issue with Resource Management whereupon redistributing the booking allocation from one user to another and changing the Booking Type for one of them was updating each users' Availability incorrectly. The applied resolution was to modify the function to better handle the changing of the Booking Type in order that the availabilities update correctly.
Timesheet
R&D #: TE-27608 | Ticket #: 169638
  • Fixed an issue with Timesheet Manager wherein, while using either Internet Explorer or Chrome, attempting to vertically scroll down the list on the Timesheet Manager page, using the mouse scroll wheel, was only working when the cursor was over the scrollbar.
Tools
R&D #: TE-28595 | Ticket #: 169154
  • Fixed an issue with Expense Audits wherein changed values and comments were not being saved even though the Expense Entry and Expense Reports auditing are on. The applied resolution was to add the missing data to Expense Audit.
Work Breakdown Structure (WBS)
R&D #: TE-27560 | Ticket #: 169387
  • Fixed a performance issue with Client PO wherein Client PO Summary was timing out or taking too long to execute. The applied resolution was to modify the function to enhance the speed and reduce the number of load time.
