2016 R1 SP17 - Resolved Issues
Below is a summary of the main issues addressed by this release.
1371.02.09.2017.V1.EB
Note: This page could be updated as new information becomes available.
Financials
R&D #: TE-29472, TE-30370 | Ticket #: 176895, 179012
  • Fixed an issue with Cost and Billing Rules whereupon associating a User to a Billing Rule was resulting in a timeout. The applied resolution was to improve the performance.
R&D #: TE-29885 | Ticket #: 178118
  • Fixed an issue with Invoices wherein the Next and Previous page navigation arrows under the Projects tab within the Invoice Edit page were not displaying in blue to indicate that more pages are available to view. The applied resolution was to show the Next and Previous navigation arrows accordingly to indicate available paginated content.
R&D #: TE-30058 | Ticket #: 178283
  • Fixed an issue with the Multi Client Invoice Manager Edit page where the “Invoice(s) generation completed” property under the General tab was incorrectly named as such. The applied resolution was to correct the property label to now read “Invoice Batch templates”.
Integrations
R&D #: TE-30183| Ticket #: 161689, 178910
  • Fixed an issue with the Great Plains integration wherein attempting to export Invoices with Expenses to Great Plains generated an error, which was the result of the Regional Settings. The applied resolution was to calculate all values with dot separator upon exporting the data to Great Plains.
R&D #: TE-30268| Ticket #: 176379
  • Fixed an issue with the Quick Books integration wherein the Class of the transaction, upon exporting an Invoice with Time Entries to QuickBooks, was not being captured. The applied resolution was to set the Class of the transaction accordingly upon the export.
Organization breakdown structure (OBS)
R&D #: TE-28424| Ticket #: 173271
  • Fixed an issue with Role Import whereupon importing Roles from an excel sheet was failing. The applied resolution was to modify the import function to allow for the successful import process.
Reporting
R&D #: TE-28943| Ticket #: 174543
  • Fixed an issue in Reports, wherein Expense Entries belonging to an Expense Report, which was excluded from an Expense Payable Batch, was inadvertently returning the Batch number with the Expense Entries that made part of the excluded Report in both an AdHoc and Upland Analytics Report. The applied resolution was to modify the logic.
R&D #: TE-29433| Ticket #: 176411
  • Fixed an issue with Reports whereupon clicking on the Security tab of a Reports tab was resulting in an error.
Resource Management
R&D #: TE-26136| Ticket #: 164864
  • Fixed an issue with the Resource Management Work Plan where the booking bar was displaying in the default color despite having changed the color for the given Custom Selection through the Chart Formatting tab under Manage Views. This was due to issues with the formatting of Custom Selections on Chart view.
R&D #: TE-30048| Ticket #: 178828
  • Fixed an issue with the Resource Management Work Plan whereupon attempting to Find Matches based on two Skills selected through the Advanced Criteria using the “And” to combine both skills was showing resources who not only have both skills, but also incorrectly showing those with either of the skills. The applied resolution required adding conditions to enforce the selected combine setting.
R&D #: TE-30098| Ticket #: 178987
  • Fixed an issue with the Resource Management Work Plan whereupon attempting to copy a booking was generating an error message.
Timesheet
R&D #: TE-28849| Ticket #: 162476
  • Fixed an issue with Timesheet whereupon using the Tab key to navigate from one field to a dependent field was resulting in the dependent field being cleared of all the associated options.
R&D #: TE-30193| Ticket #: 179315
  • Fixed an issue with Leave Time whereupon attempting to delete a Leave Time Rule was resulting in an error message generating due to invalid dependencies. The applied resolution was to modify the function to allow for the deletion of the Rule.
R&D #: TE-30672| Ticket #: 181481
  • Fixed an issue with Timesheet wherein the width of the Projects options in the Timesheet was not being fully expanded upon clicking on it the first time. The applied resolution was to modify the function to auto Expand the options upon clicking on it.
