PSA 2020 R1 SP3- Product Enhancements
Below is a summary of the features included in the PSA 2020 R1 SP3 release.
2020.03.26.2020R1.V1.EB
Note: This page could be updated as new information becomes available.
Upland Analytics
The current version of PSA release expands to multiple Upland Analytics releases and highlights many powerful new enhancements as well as improvements to the user experience. For more information on the latest version of Upland Analytics visit the Upland Analytics help center.
Upland Analytics 2020 R1.2.2
Further details can be found in the Upland Analytics 2020 R1.2.2 Release Notes.
- Modified On-Page Filter Functionality. (UA-10045)
Further details can be found in the Upland Analytics 2020 R1.2 Release Notes.
- Ability to Minimize the Drilldown Details Window. (UA-4988)
- Fonts Modified in the Dashboard Text Box Area. (UA-5664)
- Ability to Toggle On-Page Filters On/Off. (UA-6319/9093)
- Modified Radial Gauge Meter Tab. (UA-6333)
- UA Sync API now Updates Column Types on Views Page. (UA-6438)
- Modified Filtering Process to Filter on Field ID Instead of Actual Data. (UA-6497)
- Basic Auth used for UA Authentication. (UA-6736)
- Pivoted Report Queries are now Cached. (UA-6948)
- Ability to Copy UA Data Views. (UA-8316)
- Ability to Copy UA Data Sources. (UA-8324)
- Report Queries are now Logged for Analytics. (UA-8331)
- Improved Validation when Creating a Data Source. (UA-8338)
- Ability to Display Cumulative Amounts on a Bar Graph. (UA-8338)
- Update Text and Icons on the Load Warning Message. (UA-8524)
- Update Header Color and Font Size for Static Messages. (UA-9061)
- Ability to Remove the Legend on a Bubble Chart. (UA-5552)
- The Total Value of Bars now Displays on Stacked Bar Graphs. (UA-5553)
- HTML encoding is now allowed. (UA-4774)
- PGSQL - Custom fields are now working correctly. (UA-5189)
- Currency format now displays correctly on dashboards. (UA-5322)
- When creating a dimension custom field and using it in a drill-in, the custom field is now correctly hyperlinked to the report that contains the same custom field. (UA-5479)
- The Footer pane now displays correctly. (UA-5933)
- You are now able to successfully email a report and create a subscription. (UA-6253)
- The Actualize Consulting report now displays correctly. (UA-6299)
- You can now successfully wrap content using the Wrap Content option in Report Settings. (UA-6479)
- Joins are now working successfully. (UA-6632)
- Aggregate functions are now working successfully. (UA-6633)
- Formulas are now working successfully. (UA-6634)
- You are now able to create a "WHERE clause" custom field using fields that are in the "Used but not reported on" box and successfully run the report. (UA-6708)
- Fields in the "Used but not reported on" box are no longer removed when the widget type is changed. The custom field now retrieves the correct values. (UA-6751)
- Permissions now display correctly on reports and dashboards. (UA-6752)
- Subtotals now display correctly on offline reports. (UA-6809)
- The Pareto chart icon now displays when creating a drilldown. (UA-7481)
- Filter issues have been resolved. (UA-7589)
- Pareto chart display options are working correctly for reports. (UA-7603)
- Drilldowns are now working correctly on Pareto charts. (UA-7632)
- You are now able to successfully delete the last folder in the Navigation menu. (UA-7821)
- Name Override settings for pivoted columns are now correctly displaying. (UA-7876)
- Widgets with the Show in Upland WorkCenter permission now display correctly. (UA-7894)
- Dropdown menu lists have been improved. (UA-8265)
- You can now successfully apply filters on non-inserted fields. (UA-8388)
- You can now successfully run an offline report. (UA-8507)
- Totals display correctly on newly configured data sources. (UA-9224)
