PSA 2020 R1 SP5 - Release Notes
Below is a summary of the resolved issues as of PSA 2020 R1 SP5:
2020.06.17.2020R1SP5.V2.EB
Note: This page could be updated as new information becomes available.
Dashboards
Ticket #: 465766 | TE-64112
  • Fixed an issue with the Group Leave Time calendar (Portals > Dashboards) wherein it was not possible to navigate to the previous/next months by clicking the Calendar arrow buttons or to view more Leave Requests by clicking the Show more link.
Expense
Ticket #: 456495 | TE-63085
  • Fixed an issue with Expense Manager whereupon attempting to open an Expense Report containing an Entry with erroneous Total Tax value was resulting in an error message.
Ticket #: 457344 | TE-63181
  • Fixed an issue with Expense Import Transactions wherein no transactions were being imported for a specific .csv file format.
Global Search
Ticket #: 455617 | TE-62984
  • Fixed an issue with the User Defined Fields wherein incorrect UDF values were being populated upon accessing the User edit through Global Search.
Leave Request
Ticket #: 445240 | TE-62684
  • Fixed an issue with Leave Requests wherein the last updated date/time stamp of the Leave Request was not being set upon transitioning.
Login
Ticket #: 407010 | TE-63859
  • In previous releases, the Sign me in automatically feature stored a persistent cookie, retained even after the User logged off of the application using the "Log Off" functionality (User profile > Log Off). In this release we have changed how this cookie is managed and now delete it when the "Log Off" functionality is used.
    Note that simply closing and re-opening the browser does not clear the cookie. If you have selected Sign me in automatically and close the browser, upon your next login, you will be logged in automatically.
Organization Breakdown Structure (OBS)
Ticket #: 454939 | TE-62953
  • Fixed an issue with User edit whereupon attempting to create a new Billing Rule with a Task dependency resulted in an error message if the total number of characters in the names of the Client, Project, Work Type and Task exceeded 128 characters.
Ticket #: 465978 | TE-64017
  • Fixed an issue with User edit wherein a logged user without the Create right on Cost/Billing Rule was unable to save a Rate Rule association.
Ticket #: 467781 | TE-64149
  • Fixed an issue with User edit wherein a logged user with View rights on Users was able to modify User Role associations (Setup > Organization > Users > Employment tab). The resolution was to prevent users without the Modify rights on Users to be able to change a User's Role association.
Ticket #: 467781 | TE-64152
  • Fixed an issue with User edit wherein a logged user with View rights on Role was able to modify the Role Members. The resolution was to prevent users without the Modify rights on Roles to be able to remove/add User(s) on the Role Members (Setup > Organization > Roles > Role Edit).
Ticket #: 468613 | TE-64228
  • Fixed an issue with User edit wherein a logged user with View rights on Users was able to modify User Overtime Policy and Workflow Roles. The resolution was to prevent users without Modify rights on Users to be able to view/modify User Overtime Policy and Workflow Roles (Setup > Organization > Users > User Edit > Entry Options tab).
Ticket #: N/A| TE-64677
The layout of the Skill association page was improved as follows:
  1. Addition of resizing capability to the table columns.
  2. Decreased the size of the left section.
  3. Increased the size of the dialog box (where applicable).
Work Breakdown Structure (WBS)
Ticket #: 462734, 465895 | TE-63648
  • Fixed an issue with Projects whereupon attempting to add a User to the Project Team triggered an error message. The applied resolution was to modify the function to allow Security Profiles with Project Modify rights on Projects to be able to modify the Project Team.
Ticket #: 457736 | TE-63468
  • Fixed an issue with Clients wherein Client Contact(s) created via the API were not being listed in the Contact List page when browsing for a Project Contact (Project List > Project edit > Options).
Ticket #: 466904 | TE-64092
  • Fixed an issue with Project Work Plan whereupon accessing the User Work Plan from a Project Work Plan resulted in the Project Work Plan page to be cleared when using the Chrome 83.0.4103.61 Browser.
Ticket #: 467634 | TE-64200
  • Fixed an issue with Project Planner whereupon trying to access the Project Planner, having a Default Calendar where all days were Set as Working Days (Setup > Organization > System > Project Planning), triggered an error message.
Ticket #: 467343 | TE-64148
  • Fixed an issue with Project Planner wherein an error message was displayed upon accessing the Project Planner due to multiple Tasks having the same sequence number. The applied resolution required modifying the function to load the Project Planner without error and to allow the user to reorder the Tasks accordingly.
Ticket #: 454392, 456966, 458743 | TE-63509
  • Fixed an issue with Groups whereupon attempting to add a Work Type to a Group who’s members had assignments Against Tasks which ended in the past, was triggering an error message. The applied resolution was to modify the logic to set the Assignment End Date to the Task End Date if the Task End Date is prior to the Current Date otherwise, to set it to Current Date.
Ticket #: 470705,471015 | TE-64565
  • Fixed an issue with Budgets wherein Budget Threshold notifications were not being sent and the Project/Task was not being Suspended as expected.
