PSA2020 R2.1 - Release Update
Below is a summary of the new Feature and Resolved Issues included in the PSA 2020 R2.1 Release Update.
Note: This page could be updated as new information becomes available.
Feature:
Addition of new Request List Type Filter option (TE-64718)
Description: A new Filter option has been added to the Work Plans allowing you to view the Resource Requests based on a Request List Type. The available options are:
- Created by me: Filters the Requests based on the those created by the logged user.
- Assigned to me: Filters the Requests based on the those that are assigned to the logged user.
- Select all: Filters the Requests based on the those created by the logged user and those that are assigned to the logged user.
Resolved Issues:
Automation
Ticket #: 521627 | TE-66537
- Fixed an issue with Automation Service wherein the Process PO Notification failed upon processing.
Financial
Ticket #: 522378 | TE-66579
- Fixed an issue with Multi Client Invoice Manager wherein the selected Use Opportunity Contact option was not being retained upon generating an Invoice.
Ticket #: 499544, 518641 | TE-65991
- Fixed an issue with Multi Client Invoice Manager wherein the Clients list took a long time to load.
Ticket #: 522228 | TE-66552
- Fixed an issue with Multi Client Invoice Manager wherein the Invoice Batch was regenerated after changing it's status.
Ticket #: 522228 | TE-66592
- The Mass Update of Invoices capability, previously located in the General tab of the Invoice Batch is now renamed to Update All Invoices and located on the Invoices tab.
Note: All Invoices included in the Invoice Batch must be in the same State when using Update All invoices.
Ticket #: 517642 | TE-66382
- Fixed an issue with invoicing wherein the chosen Default Invoice Workflow (Setup > Financial > System > Invoice) was not being reflected, upon creating a new Invoice Batch.
Ticket #: 522143 | TE-66595
- Fixed an issue with Multi Client Invoice Manager wherein attempting to generate Invoices could result in a timeout warning message.
Login
Ticket #: 493396, 501782 | TE-65933
- Fixed an issue with Login wherein the Sign me in automatically was not working as expected when trying to access the application using a URL that contained any session information where no active session existed.
Organization Breakdown Structure (OBS)
Ticket #: 497045 | TE-65786
- Fixed an issue with User Security wherein Users with View, Modify, Edit, and Delete access rights to Resource Type and Leave Time, were unable to access Overtime Policy and Leave Time from the Resource Type Edit page (Setup > Organization > Resource Types).
Ticket #: 496406, 521848 | TE-65865
- Fixed an issue whereupon attempting to upload a Company Logo (Setup > Organization > System) was unsuccessful.
Ticket #: 495216 | TE-65915
- Fixed an issue with Audit Trail, wherein the Project Name was missing from the Event Detail when creating a new Project.
Reporting
Ticket #: 492502, 497322, 523930 | TE-65653
- Fixed an issue with Upland Analytics wherein Reports with Formulas or If Functions listed in the Used but not reported on section were failing to execute.
Ticket #: 518289, 520691, 521773 | TE-66515
- Fixed an issue wherein Upland Analytics was not loading for some users.
Resource Management
Ticket #: 524094, 524197 | TE-66554
- Fixed an issue with the Work Plans, wherein over-allocated hours were not displayed in red until the page was refreshed.
Ticket #: 520024 | TE-66554
- Fixed an issue with the Work Plans, whereupon modifying multiple User bookings at the same time could result in the creation of new bookings against the shared Role.
Timesheet
Ticket #: 518272, 518295 | TE-66386
- Fixed an issue with Timesheet workflows whereupon transitioning the Timesheet through a workflow having at least two States assigned to Project Manager resulted in a Faulted Timesheet.
Ticket #: 524094, 524197 | TE-66702
- Fixed an issue with Timesheet wherein the Out of office functionality was not reassigning Timesheets accordingly.
User Defined Fields
Ticket #: 524191 | TE-66701
- Fixed an issue with User Defined Fields associated to Client Contacts wherein the UDFs were missing post upgrade to 2020 R2.0.
Work Breakdown Structure (WBS)
Ticket #: 499543, 520695, 522882 | TE-65985
- Fixed an issue with Project Edit wherein the PO Line Items widget was missing for users who had chosen a specific Project Overview prior to 2020 R2.0 upgrade .
Ticket #: 505236 | TE-66204
- Fixed an issue with Task Entry Mass Update, wherein an un-scoped User could not see tasks belonging to a scoped project.
Ticket #: 498972 | TE-65925
- Fixed an issue with Milestone Billing wherein a User without the edit right on Billing Rule was unable to use the Billing Date Picker, and modify the Charge and Work Type options.
Ticket #: 501181 | TE-66026
- Fixed an issue with Project Edit wherein opening a Project from the Hierarchy View, failed to display the information in the Milestones, Team Members, Invoices & PO Line Items lists.
