2020 R2.3 - Release Update
Below is a summary of resolved issues as of PSA 2020 R2.3 Release Update.
Note: This page could be updated as new information becomes available.
Upland Analytics
This version PSA includes the Upland Analytics 2020 R1.3 release. For more information visit the Upland Analytics 2020 R1.3 Release Notes
- Improved Date Functions - Addition of the ability to Select Specific Dates or Yesterday/Today/Tomorrow
- Addition of the ability to Hide Label on Scatter Graph
- Addition of the ability to Edit a Report or Graph/Chart when a Field is missing
- Addition of Week Formatting for Reports and Graphs/Charts
- Reports Containing Date Fields now export as Dates in Excel
Below is a summary of the main issues that were fixed in this release:
- You are now able to save a column layout when the Reset column layout when new column is found option is enabled. (412814, 479332)
- Scrolling in the Edit Filter dialog box has been fixed. (414354)
- The default column layout setting has been changed to Size Based on Best Fit. (427290)
- The column heading in downloaded Pivot reports now display correctly. (451240)
- You are now able to successfully run the Cost Models report. (459507)
- Custom fields in reports now display in the same order as in the Columns section. (469754)
Resolved Issues
Automation
| 536536 | TE-67683 | Fixed an issue with the Automation Service wherein under some conditions the Project Initialization Service was failing. |
Financial
| 361134 413193 |
TE-56610 | Improved the performance of Client PO page. |
| 522143 | TE-67651 | Improved the performance of Multi Client Invoice Manager when attempting to post a Batch containing a large volume of Invoice transactions. |
| 536303 | TE-67670 |
Most Financial Planner columns, can now be resized. Note: The Grand Total column, cannot be resized. |
| 549684 | TE-68660 | Fixed an issue in Financial Planner wherein under certain User Forecast Cost/Billing Rate choices, forecasting data was not being automatically regenerated to reflect a change in the rate. |
Organization Breakdown Structure (OBS)
| 539498 | TE-67868 | Fixed an issue with User Security wherein a User without the admin right on Invoice was able to modify an Invoice State by accessing it through the Project List. |
Project Planner
| 494827 | TE-65577 | A warning message is now being displayed upon attempting to modify the duration or the Start/End dates of a Task which has a Budget that will be effected by the change. |
Reporting
| 278545 399667 |
TE-46820 | Fixed an issue with Upland Analytics wherein the Date fields were being exported as Text format to Excel. |
| 262897 | TE-43938 | Fixed an issue with Upland Analytics whereupon running a Pivot report, Field(s) used both as a Column and Measure were missing . |
| 392471 | TE-58183 | Fixed an issue with Upland Analytics whereupon attempting to run a Report that included a Custom Field which was similarly named as an out-of-the-box field was resulting in an error message. |
| 421497 | TE-60175 | Fixed an issue with Upland Analytics wherein a Custom Field, created with either a Count or Count Distinct function and used as a Pivot, was returning values in decimal format instead of integer. |
| 452674 | TE-62816 | Fixed an issue with Upland Analytics wherein the placement order of Custom Fields within the Columns section was being reordered upon saving the report. |
| 455204 | TE-63006 | Fixed an issue with Upland Analytics wherein the incorrect Total percentages were being displayed when running a Stacked Bar Report with the Horizontal Bar display option (Report Settings > Stack tab) selected. |
| 451702 459351 462975 |
TE-63488
TE-63725 |
Fixed an issue with Upland Analytics wherein Measure fields with decimal points were being rounded incorrectly in Pivot reports. |
| 465620 | TE-63954 | Fixed an issue with Upland Analytics wherein filtered Custom Fields were returning erroneous values. |
| 467266 525899 |
TE-64120 | Fixed an issue with Upland Analytics wherein users with Upland Analytics Read Only rights were able to modify a report previously created by them. |
| 389225 | TE-57532 | Fixed an issue with Upland Analytics wherein the same Field used as a Column and also as a Grouped by option when pivoting, were missing upon running the report. |
| 561660 | TE-69539 | Fixed an issue with Upland Analytics whereupon impersonating a user and viewing a report where a Filter was applied based on Current logged in user, the shown data was based on the impersonating user instead of the impersonated one. |
Resource Management
| 536304 | TE-67671 | Fixed an issue with the Work Plans whereupon turning the Heat Map off then modifying the Heat Map Tolerance color values and turning the Heat Map back on resulted in the old colors to be shown. |
| 563178 | TE-69484 | The available options within the Booking Attributes list boxes are now sorted in alphabetical order. |
Timesheet
| 541204 | TE-68048 | Fixed an issue with Timesheet Manager wherein a Project Manager who was also a Users' Approval Manager was unable to see the User's Time Entries within the Assigned Timesheets View if the Partial Rejection option was turned on for the Workflow Assignment Rule. |
| 564849 | TE-69563 | Fixed an issue with Timesheet Manager wherein a Group Manager was unable to see the User's Timesheet when Prevent Self Approval was turned on for Project Managers. |
| N/A | TE-68500 | To comply with General Data Protection Regulation (GDPR) the Timesheet Manager Tooltip now shows the sum of all contained Leave Time as a summary row titled Leave Time. |
| 560136 | TE-69315 | Improved the performance of transitioning Timesheets. |
| * | TE-69336 | Fixed an issue with Timesheet whereupon accessing a Timesheet configured to Show Timesheet History resulted in an error message. (* Zendesk ticket ids: 562016, 562022, 562028, 562029, 562035, 562036, 562040, 562048, 562050, 562062, 562063, 562064, 562065, 562066, 562071, 562072, 562073, 562078, 562082, 562087, 562096, 562097, 562098, 562106, 562120, 562125, 562133, 562137, 562139, 562140, 562144, 562149, 562150, 562153, 562155, 562169, 562173, 562187, 562192, 562197, 562198, 562208, 562216, 562228, 562236, 562237, 562241) |
Workflows
| 533002 | TE-67412 | The Sender for Expense Rejection Notification email will now show the Sender Name as it already did in Timesheet Notifications. |
Work Breakdown Structure (WBS)
| 535886 | TE-67663 | Fixed an issue in the Project Milestones list wherein if the Billing Milestone column was not present in the table, changes made to the Billing attribute in the drawer were not saved.
| 537531 | TE-67754 | Fixed an issue with Project Edit, whereupon saving a Project with xml incompatible characters in the Description resulted in an error message. |
Addendum 2.3.1
Timesheet
| 570509, 570513, 570651 |
TE-70039 | Fixed an issue wherein Assignments past their End Date were being listed within a User's Timesheet. |
Addendum 2.3.2
Project Planner
| 572638 | TE-70270 | Project Plans containing a Task with Budget associations can now be saved regardless of the chosen Regional Date Settings. |
Addendum 2.3.3
The 2.3.3 Addendum delivers Upland Analytics 2020 R1.3.6 and includes the following resolved issues:
| 573393 577085 580450 |
TE-70326 TE-70762 |
Users with the Upland Analytics Read Write access right are now able to successfully copy a report created by another user. |
| 574491 | TE-70442 | Fixed an issue with Upland Analytics whereupon running a report containing some Custom Fields resulted in an error. |
| 576881 | TE-70617 | Fixed an issue with Upland Analytics whereupon trying to save a Custom Field after turning the Enable threshold settings option off, resulted in an error. |
| 576468 577710 578535 |
TE-70625 | You are now able to successfully run Upland Analytics reports using Custom Fields with If condition(s). |
| 454020 533102 |
TE-65565 TE-67817 |
Fixed an issue with Upland Analytics wherein the On-Page Filter(s) were being ignored upon exporting the report as CSV/XLS files and downloading them from the File Manager. |
| 571785 | TE-70227 | Custom Fields contained within Pivot Reports now display the accurate number of decimal points. |
