PSA 2020 R3.0.5 - Release Update
The 2020 R 3.0.5 Release Update delivers Upland Analytics 2020 R1.6.1, including these listed Resolved Issues.
For a summary of the features included in the Upland Analytics 2020 R1.6 release click here. Further details on Upland Analytics can be found in the Upland Analytics help center.
Note: This page could be updated as new information becomes available.
Resolved Issues
| 521847 | TE-66532 | Fixed an issue with Upland Analytics, whereupon sharing a Report with multiple users, caused the Edit (Save) button to be pushed off the visible page area. |
| 460151 | TE-63540 | Fixed an issue with Upland Analytics, whereupon selecting the option to Group multiple columns resulted in some of the columns to display multiple times when running the Report. |
| 588641 592490 |
TE-71831 | Fixed an issue with Upland Analytics, wherein the If Function Type applied to Boolean Fields used within Custom Fields would auto-reset upon exiting the Report. |
| 580450 | TE-71300 | Reports that are not originally created by the logged in user can now be copied. |
| 455633 | TE-63128 | Fixed an issue with Upland Analytics wherein the Show Subtotal option was not functioning as expected when applied on Custom Fields. |
| 544453 593946 |
TE-68257 | Fixed an issue with Upland Analytics, wherein the exported .xls or .csv column order differed from that of the original Report if it contained Custom Fields. |
| 599527 | TE-72630 | Fixed an issue with Upland Analytics, wherein an error message was being generated upon running a Pivot Report having Custom Field(s) of Type Percentage as Measure. |
| 581570 | TE-71442 | Fixed an issue with Upland Analytics Subscriptions, wherein the applied sorting order on a column was not being retained in the attached XLS report. |
| 598374 | TE-72598 | Fixed an issue with Upland Analytics wherein a Subscription for a specific Report was failing under certain conditions. |
| 585963 596933 599468 608129 609164 609380 611117 |
TE-72431 | Fixed an issue with Upland Analytics, wherein some data was missing from Reports having the Date Week Filter applied to their Fields. |
