PSA 2020 R3.1 - Resolved Issues
Below is a summary of the main issues addressed by this release.
- Automation
- Expense
- Financial
- Integrations
- Mobile
- My Home
- Notifications
- Organization Breakdown Structure (OBS)
- Product Entries
- Reporting
- Resource Management
- REST API/SDK
- Timesheet
- Work Processes
- Work Breakdown Structure (WBS)
- Other
- Release Update 3.1.1
- Release Update 3.1.2
2021.01.28.2020R3.1.V1.EB
Note: This page could be updated as new information becomes available.
Automation
| 451458 459026 491427 497523 497858 |
TE-62658 | Additional logs were added to the Timesheet initialization Automation Service. |
| 598161 | TE-72588 | Improved the performance of the Regenerate Financial Planner Data service. |
Expense
| 603700 | TE-72836 |
Fixed an issue with Expense Manager wherein assigned Expense Reports were not listed within the Assigned Reports tab under the following conditions:
Financial
| 595752 | TE-72304 | Fixed an issue with Invoices wherein the Currency box was empty if the Project Currency override option was turned off (Setup > Work > System). |
| 529336 | TE-67486 | Fixed an issue with Invoicing, wherein the logged user was able modify an Invoice after having transitioned it to a State that was no longer assigned to them. |
| 581405 | TE-71109 | Fixed an issue in Invoice Setup whereupon setting up a Batch Template Filter option and choosing to search for a Project by Client Name resulted in an error message. |
| 592877 | TE-72310 | Fixed an issue with Invoices wherein the Prepayment Charges included in an Invoice were not implicitly being included in the Prepayment Amount upon associating the PO when creating the Invoice. |
| 595898 | TE-72710 | Fixed an issue with Invoices, wherein the Currencies tab was showing for a few seconds if any of the following options were chosen for the Invoice Exchange Rate (Financial > Invoice Manager > Invoice Edit): Rate of the day, Invoice start date, Invoice end date or Entry date rate. |
| 603374 | TE-72819 | Fixed an issue with Financial Planner Templates wherein special characters contained in their Names were causing an error upon accessing them. |
| 599054 | TE-72590 | Fixed an issue with Financial Planner Templates whereupon selecting a different Template at the Project level resulted in the Date Columns to display according to the previously selected Template. The applied resolution was to include the financial Calendar selection box within the General tab of the Financial Planner Templates setting page. Note: By default, the Financial Calendar tagged as Is Default is selected. |
| 606737 612686 |
TE-73483 | Fixed an issue with posted Expense Payable Batches (Financial > Payable Batches Not Posted > History) wherein clicking on any of the tab names (Users, Expense Reports and Overview) did not successfully load the tab. |
Integrations
| 596555 597152 |
TE-72435 | Fixed an issue with QuickBooks and Great Plains integration wherein Clients having Contacts without the ability to logon to PSA can now be exported successfully. |
| 599348 | TE-72609 | The Import Status (Setup > Organization > System > CRM Integration > CRM Integration Options > Advanced Options > Import Status) table columns can now be sorted. |
| 603000 | TE-73143 | Fixed an issue wherein the Amex import was not using the defined rate within the Amex file. |
| 620722 | TE-74031 | Fixed an issue with MS Teams Integration wherein an error message was being generated upon trying to create a Team in MS Teams if a Group Name policy was in effect for the client Azure active Directory. Note that the following permissions must be granted when setting up the integration:
Mobile
| 59628 | TE-72368 | Fixed an issue with PSA Mobile wherein Users having a password containing the + sign, were unable to login. |
| 595860 | TE-72315 | Fixed an issue with PSA Mobile wherein the Purpose selection list box was displaying as an edit box upon choosing the Hotel Expense Item. |
| 596271 | TE-72365 | Fixed an issue with PSA Mobile whereupon entering Time against an assigned Task, resulted in the Time Entry to appear against the User’s Default Task (if defined) or the System Default Task if the Timesheet Template was set up to show My Tasks or My Work Types Field. |
My Home
| 594739 594777 |
TE-72234 | Fixed an issue wherein a blank page was being displayed for a logged user having the Homepage set as their Initial Page and where the Home Page Menu item was set as not visible for their Security Profile. |
Notifications
| 618216 621061 |
TE-73819 | Fixed an issue with System Notifications whereupon modifications to a Notification were not being saved and Recipient changes resulted in an error. |
| 595238 | TE-72259 | Fixed an issue with the Terminology processing in the menu to better handle disallowed characters. |
| 611902 | TE-73613 | Fixed an issue with Groups, wherein the Assigned User table was misaligned when using Firefox. |
Product Entries
| 612037 613944 |
TE-73597 | Fixed an issue with Product Entries wherein Tasks flagged as Used By: Products were not appearing unless Used by: Money Charges was also flagged. |
Reporting
| 578208 | TE-70838 | You can now act on an Invoice upon clicking an Invoice Reference Number (invoice Link Field) from an Upland Analytics report provided that you have the proper rights to do so. |
| 612142 | TE-72101 | Fixed an issue with Programs wherein users without the View right to Portfolio, were unable to associate Project(s) to a Program. |
| 594862 | TE-72363 | Fixed an issue with Reports wherein Group Managers without the Can Report on Any User Scope permission (Setup > Organization > Users > User Edit) were able to view all User Leave Time Entries when running the Leave Time report (Reports > Leave Time). |
| 594697 | TE-72235 | Fixed an issue with Upland Analytics whereupon choosing to sort a report by the Project Link Field resulted in incorrect sorting. |
| 604836 608600 |
TE-73229 | Fixed an issue with Ad-hoc Reports whereupon modifying Report and saving it cleared out the Filter Text Field Parameters. |
| 614892 | TE-73666 | Fixed an issue with Upland Analytics wherein the Project Allocation Hard Booking Hrs was showing double the amount of allocated hours. |
Resource Management
| 595879 | TE-72316 | Fixed an issue with Work Plans wherein an error message was being generated upon clicking the Save & New link within the New Booking dialog box. |
| 595310 | TE-72248 | Fixed an issue with Project Scheduling wherein the Task list was empty when using the Quick Add functionality. |
| 596526 | TE-72426 | Fixed an issue with Project Work Plan wherein the Project Team Members View was empty upon attempting to find matches. |
REST API/SDK
| 605513 | TE-72991 | When creating a User using the API, Licence count is now properly checked. |
| 610164 | TE-73365 | When creating a Task using the API, the Enable ETC option of the Work Type is now inherited. |
Timesheet
| 594693 594768 |
TE-72199 | Fixed an issue with the Timesheet Manager wherein some entries, under certain conditions, were missing from the list when View Assigned Timesheet As All was selected. |
| 604024 | TE-72893 | Fixed an issue with Timesheet Manager wherein some Time Entries were missing upon selecting the Assigned Timesheet View As All option for an Approval Group Manager. |
| * | TE-72518 | Fixed an issue with Timesheet Manager wherein, attempting to vertically scroll down the list on the Timesheet Manager page, using the mouse scroll wheel, was only working when the cursor was over the scrollbar. (* Zendesk ticket ids: 597961, 614933, 615553, 616211, 617112, 618091, 618259, 618333, 618511, 618877, 618899, 618917, 619257, 620288, 620992, 621767, 621868, 621928, 622974) |
Work Processes
| 593687 | TE-72182 | Fixed an issue with Work Processes wherein the logged user was able to act on an Entry, after having transitioned it to a State that was no longer assigned to them, when using Microsoft Edge. |
| 595871 | TE-72366 | Fixed an issue with Work Processes wherein the associated User Defined Fields could be modified while the Entry was in a read-only State. |
| 594619 597213 |
TE-72232 | The browse for Tasks option now utilizes the contains-in logic search functionality. |
| 579985 | TE-70921 | The Invoices Not Posted list (Setup > Work > Clients > Client Edit > Invoice) can now be sorted in ascending or descending order based on the Amount column. |
| 579974 | TE-70933 | An error message is now being displayed upon trying to change the Project of a Task with Billing/Cost associations with Time Entries against the Task informing you: “You cannot modify or delete this record. Please replace or remove the Rate Rule associations before making any such modification.” |
| 589642 | TE-71848 | Fixed an issue with Clients wherein an Access Denied message was being triggered upon trying to open the POs tab if the Client Name contained some special characters such as the @ sign. |
| 596561 | TE-72427 | Fixed an issue with Project Planner, wherein Resource Bookings were not being saved under certain conditions. |
| 596081 | TE-72454 | Fixed an issue with Projects, whereupon trying to modify a Task Name (Project List > Project Edit > Manage tab > Tasks) using inline editing, resulted in an error message if the Start Date and End Date Columns were removed from the table. |
| 608497 | TE-73232 | Fixed an issue with Project Overview wherein duplicated lines and incorrect values were being displayed when scrolling a long list of Team Members. |
Other
| 602130 602208 |
TE-72743 | Fixed an issue with the on-page Filters wherein the Filter settings within the Project Task (Project List > Project Edit > Tasks) inadvertently tied to that of the User List instead of the Tasks list (Setup > Work > Tasks). |
Reporting
| 578208 | TE-74249 | You can now access a Project, Expense, Timesheet or Invoice through their respective Link Field from an Upland Analytics report. |
Financial
| 628065 | TE-74255 | Fixed an issue with Financial Planner wherein an error message was being generated upon trying to access a Project's Financial Planner in Forecast View, where: A- Fixed Fee with Milestone was selected as Revenue Forecast Method and B- Total completion time percentage (Actual time or Planned time ) was less than the Milestone Cumulative % (Milestone Billing Amount) |
Mobile
| 628366 | TE-74278 | Fixed an issue with Mobile Expense Reporting wherein the list of Expense Items was not being filtered based on the chosen Project/Task. |
Reporting
| 628366 | TE-74262 | Decommissioned User(s) can now be selected and added to the selected table when browsing for Users within RDLC reports. |
| 628076 | TE-74261 | You can now successfully save Project Billing Milestones regardless of the chosen Regional Date Settings. |
| 627922 628103 628112 |
TE-74265 | When searching for Tasks by Name within the Assign Tasks page, the list of Tasks is now returned as expected. |
