PSA 2020 R3.1.3 - Release Update
The PSA 2020 R3.1.3 Release Update delivers Upland Analytics 2020 R1.7.2, including these Resolved Issues.
For a summary of the features included in the Upland Analytics 2020 R1.7 release click here. Further details on Upland Analytics can be found in the Upland Analytics help center.
Note: This page could be updated as new information becomes available.
Resolved Issues
Upland Analytics
| 628074, 633570 |
UA-11774 | Fixed an issue with Upland Analytics wherein the Week Start Date was defaulting to Monday instead of Sunday. The applied resolution resets the Week Start Date to Sunday as it was prior to Upland Analytics 2020 R1.6.1 release. Note: If you are interested in setting the Week Start Date to Monday, contact contact PSA Support to discuss your specific business requirements. |
| 635853, 623660 | TE-74718, TE-74206 | Fixed an issue with Upland Analytics wherein the On-Page Filters were being ignored for exported/saved CSV/XLS reports within the File Manager. |
| 626553 | TE-74299 | Fixed an issue with Upland Analytics wherein the Subscriptions were failing due to a report failure. |
| 617311 | TE-73765 | Fixed an issue with Upland Analytics wherein the column header Date Formats were inconsistent upon pivoting on a date and using D/M/Y as the Display Format. |
| 620230 | TE-73966 | Fixed an issue with Upland Analytics whereupon modifying a Pivot report and previewing it, resulted in an error message being generated. |
| 618178 | TE-73831 | Fixed an issue with Upland Analytics wherein the calculated value for some Custom Fields were incorrect under certain conditions. |
| 617349 | TE-73803 | Fixed an issue with Upland Analytics wherein a Boolean Field used in a Pivot Report was showing incorrect values. |
| 611638 | TE-73524 | Fixed an issue with Upland Analytics wherein, under certain conditions, an error message was being generated upon trying to modify a Custom Field. Note: If the error message "Please delete any Custom Fields that is not being used from your report" is displayed, please ensure that unused Custom Fields are either deleted or moved to the Used but not reported on section. |
| 529106 | TE-67232 | The On-Page filter interface has been redesigned. |
