PSA 2021 R1.0 - Resolved Issues
Below is a summary of the main issues addressed by this release.
- Audit Trail
- Integration
- Expense Manager
- Financial
- Financial Planner
- Leave Request
- Login
- Mobile
- Notifications
- Organization Breakdown Structure (OBS)
- Reporting
- Resource Management
- REST API/SDK
- Timesheet
- Tools
- Work Breakdown Structure (WBS)
2021.05.17.2021R1.V1.EB
Note: This page could be updated as new information becomes available.
Audit Trail
| #660214 | TE-75968 | Fixed an issue with Audit Trail wherein the Logon audit was not being recorded if the Sign me in automatically option was selected. |
Integration
| 597152 | TE-73026 | Fixed an issue with Great Plains Integration whereupon attempting to export Clients under certain conditions, resulted in an error message. |
Expense Manager
| 634831 | TE-74727 | Fixed an issue with the Expense Manager wherein the tooltip available for a State assigned to the Project Manager was not displayed under certain conditions. |
Financial
| 626995 | TE-74215 | Fixed an issue with the Invoice Manager page, wherein visited/viewed Invoice Batches remained selected within the list page. |
| 609841 | TE-73892 | A warning message now displays instead of an error one when attempting to create Charges against an Invoice with prior PO associations. Furthermore, upon clicking Back an information message is now being displayed instead of a warning one. |
| 616256 | TE-73773 | Fixed an issue with Invoicing wherein Projects without a shared Scope with their Client were not being included within the Invoice Batch. |
Financial Planner
| 628065 | TE-74255 | Fixed an issue with Financial Planner wherein an error message was being generated upon trying to access a Project's Financial Planner in Forecast View, where:
A- Fixed Fee with Milestone was selected as Revenue Forecast Method and B- Total completion time percentage (Actual time or Planned time) was less than the Milestone Cumulative % (Milestone Billing Amount). |
| 638949 | TE-74851 | Fixed an issue with Financial Planner wherein the View sometimes defaulted to Combined and the Calendar to 1901. |
| 636449 | TE-74682 | Fixed an issue with Financial Planner Templates whereupon selecting a different Template at the Project level resulted in the Currency to display according to the previously selected Template. |
Leave Request
| 639339 | TE-74854 | Fixed an issue with Leave Request whereupon deleting an approved Leave Request under certain conditions, resulted in the Leave Time Entry to remain within the User’s Timesheet. |
Login
| 614862 | TE-74141 | Fixed an issue with SSO login, wherein under certain conditions an error message was being triggered. |
Mobile
| 628366 | TE-74278 | Fixed an issue with Mobile Expense Reporting wherein the list of Expense Items was not being filtered based on the chosen Project/Task. |
| 672982 | TE-76599 | The Preferred Terminology Names now display as expected when using the Mobile app. |
Notifications
| 495449 559285 632305 |
TE-74073 | Fixed an issue with Notifications wherein under certain conditions, the Notification was being sent out with an erroneous User Name. |
| 636983 | TE-74713 | Fixed an issue with Security wherein users with the Assign Users to Task permissions, were unable to assign Task(s) to User(s) through the Project Team page. |
Reporting
| 626830 | TE-74281 | Fixed an issue with Upland Analytics wherein the Task Allocation Actual Billable Hours Field value (Task Scheduling Data Source) was being multiplied. |
| 628366 | TE-74282 | You can now access a Project, Expense, Timesheet or Invoice through their respective Link Field from an Upland Analytics report. |
| 626586 | TE-74220 | Improved the performance of the VIEWTIMEENTRY view. |
| N/A | TE-75299 | Fixed an issue with Reports wherein a folder was missing from the Application tab. |
| 628366 630058 |
TE-74262 | Decommissioned User(s) can now be selected and added to the selected table when browsing for Users within RDLC reports. |
| 626045 | TE-74167 | Fixed an issue with PSA Reports wherein navigating between the tabs was not possible. |
| 628150 628517 |
TE-74257 | Fixed an issue with PSA Reports wherein the selected Project and Client parameters were not being saved. |
| 636677 | TE-74680 | Fixed an issue with the Detailed Leave Time Report wherein leaving the Users/Groups Parameter boxes empty resulted in all User’s Leave Time being displayed. Note that both Project and User Parameters must be selected for the Report to return data. |
| 636695 | TE-74681 | Fixed an issue with the Project Time Details with Notes Report wherein leaving the Projects/Work Types/Users Parameter boxes empty resulted in all Projects data to display. |
Resource Management
| 630581 | TE-74445 | Fixed an issue with the Workforce Planning Notifications, wherein the notification failed to trigger for the Allocated on a Project Action. |
| 630581 | TE-74545 | Fixed an issue with the Workforce Planning Notifications, wherein two email notifications were being sent upon modifying a Role based Soft Booking to a User based Hard Booking. |
| 630581 | TE-74546 | Fixed an issue with the Workforce Planning Notifications, wherein two email notifications for Soft Booking were being sent upon splitting a Role based Soft Booking into a User based Hard Booking and a Role based Soft Booking resulted in two Soft Booking Notifications to be sent out. |
| 618467 | TE-73871 | Clarified a situation whereupon a Role showed different availability between the top and bottom panels of a Work Plan when any matching resource was overbooked in the period. Note: The top section of a Work Plan shows Role availability as the sum total of matching Resource availability excluding overallocation, while the bottom section shows Role availability including overallocation. While some matching resources may have availability in the desired period, the overall availability within that period may not be as much as perceived. |
REST API/SDK
| 625767 625792 |
TE-74165 | Fixed an issue with the Charge API wherein no record was being created for a Custom Field. |
| 625767 | TE-74166 | The Charge API now passes the appropriate Entry Date. |
| 618996 | TE-73874 | Fixed an issue with the Project API wherein the Count was returning an error. |
Timesheet
| 642836 | TE-75092 | Fixed an issue with Timesheet Templates wherein an error message was being triggered upon attempting to add/edit Notes for a Time Entry rejected by the Project manager if the Prevent Time Entry Notes on the Read-only States was enabled in the associated Template. |
Tools
| 619683 | TE-75302 | Fixed an issue with the Import Logs wherein no logs were being displayed if the Date/Time Filter was set to Today. |
| 628076 | TE-74261 | You can now successfully save Project Billing Milestones regardless of the chosen Regional Date Settings. |
| 627922 628103 628112 |
TE-74265 | When searching for Tasks by Name within the Assign Tasks page, the list of Tasks is now returned as expected. |
| 628076 | TE-74333 | You can now successfully delete a Milestone Billing Entry if the Milestone Billing Date is set to the Project Start Date. |
| 623155 623674 |
TE-74085 | Fixed an issue with Project Milestones wherein the Detailed Audit Trail End date event was missing when completing a Milestone with an Actual Completion Date after Project End date. |
| 632568 | TE-74524 | Improved the performance of transitioning Projects to the next State. |
| 629343 | TE-74340 | Fixed an issue with Project wherein under certain conditions an error message was being triggered upon transitioning the project to the next State. |
| 640509 | TE-74874 | Fixed an issue with Project List wherein the Δ Current Time Budget value included Budgets from Tasks and Assignments which shared the same Unique Identifier as the Project. |
| 639679 | TE-75580 | Fixed an issue with Project Milestones wherein newly created Milestone(s) were not listed within the Milestone selection box upon inline-editing a Task. |
| 661866 | TE-76003 | Fixed an issue with Project Milestones wherein the previously selected Exclude From invoice selection box was reverting to unselected upon creating a Billing Milestone from the drawer. |
| 661923 | TE-76004 | Fixed an issue with Project Milestones wherein modifying the Total Amount by choosing a lower value than the original amount and choosing to propagate the change to existing entries was resulting in an error message. |
| 634672 | TE-74600 | Fixed an issue with Project Workflows wherein Projects in a Final State did not inherit a new Workflow instance upon modification. An error message now displays when attempting to change the Workflow of a Project which is not in Initial State informing you that the Project Workflow cannot be updated because the Project is not in the Initial state. |
