PSA2022-R1.1 - Resolved Issues
Below is a summary of the main issues addressed by this release.
- Automation
- Charges/Products
- Expense Manager
- Financial
- Integration
- Leave Request Manager
- Notifications
- Organization Breakdown Structure (OBS)
- Project Planner
- Reporting
- Rest API/SDK
- Resource Management
- Timesheet
- User Defined Fields
- Work Breakdown Structure (WBS)
- Workflows
- Work Processes
2022.05.18.2022R1.1.V1.EB
Note: This page may be updated as new information becomes available. Visit regularly for the latest updates.
Automation
| 880037 | TE-81667 | Fixed an issue with the Automation Service wherein under some conditions the Project Initialization Service was failing. |
| 895893 | TE-82199 | Fixed an issue with the Automation Service wherein some Projects were not being included in the Regenerate Financial Planner Data Service. |
| 891771 919220 |
TE-82430 | Fixed an issue with the Automation Service, wherein under certain conditions the Failed Notification Service was failing. |
| 997567 | TE-82839 | Fixed an issue with the Automation Service, wherein the automated Export Projects to Concur Service was generating an error message upon processing. |
Charges/Products
| 904152 920985 922832 1013713 |
TE-82282 | Money Charges can once again be deleted. |
Expense Manager
| 1000907 | TE-82940 | Under rare conditions, an Expense Report might not transition between States. Validation has been added against the Audit Trail to inform users of this occurrence so that the transition can be redone. |
| 1026882 | TE-83643 | Improved the performance of the Overview and Assigned Reports tabs. |
Integration
| 1008130 1021941 |
TE-83169 TE-83640 |
Fixed an issue with Microsoft Dynamics CRM Online integration, whereupon attempting to test the connection to Microsoft Dynamics CRM Online was unsuccessful. In order to support the new OAuth2 authentication, you will need to register the application (TS_Upland_Dynamics_365) with your Azure Active Directory instance:
From PSA:
Financial
| 900392 | TE-82175 | You can now override an Invoice Number when the Invoice is in a State flagged as Generate Invoice Number and the Read-Only option is disabled. |
| 903964 | TE-82246 | Fixed an issue with the Invoice Manager whereupon transitioning an invoice would redirect the user to page 1. |
Financial Planner
| 762623 879411 |
TE-82164 | Fixed an issue with the Invoice Manager whereupon transitioning an invoice would redirect the user to page 1. |
| 1010726 | TE-83304 | Fixed an issue with the Leave Request Calendar Default View wherein the Group selection was not retained if the Group Type was not set to Approval. |
Notifications
| 894692 | TE-82115 | Fixed an issue with Timesheet Notification wherein under certain conditions, the Notification was being sent out with an erroneous User Name. |
| 1012833 | TE-82903 | Decommissioned Group Approvers now remain visible within their Group’s list of selected Approvers. |
Project Planner
| 1002737 | TE-83035 | Fixed an issue wherein under certain conditions, an error message was being displayed upon accessing the Project Planner. |
Reporting
| 917660 | TE-82827 | Reports created with the Task Scheduling Data Source now return records for Role based Bookings. |
| 910142 | TE-82486 | The Invoice Entry Billable Adjustments Field (Invoice Entry Details Data Source) now returns Adjustments created at the Invoice level. |
| 1013657 1014509 |
TE-83340 | Fixed an issue with Upland Analytics wherein the Expense Entry Payable Amount in user curr Field was returning duplicate values for some reports. |
| 997857 | TE-83319 | You can no longer delete a Local Microsoft Report (RDLC) used as a Client or Invoice Report Template. |
REST API/SDK
| N/A | TE-82626 | Charge Entries with an amount between 0 and 0,5 can now be created through the API. |
| N/A | TE-82640 | Exchange Rate value(s) can now be created/updated when creating a Charge Entry through the API. |
| 1010628 | TE-83254 | You can no longer associate a suspended Portfolio to a Project through the API. |
Resource Management
| 886065 923196 |
TE-81863 | Improved the performance of the Work Plans when the Heat Map is turned on. |
Timesheet
| 896476 | TE-82216 | Fixed an issue with Timesheet wherein Users with the Can create Adjustments on behalf of others right were able to modify the Billable flag when entering Time on behalf of others. |
| 871577 | TE-82366 | Fixed an issue with mobile Timesheet whereupon Time Entries against an assigned Task were created against an unassigned Task/Project instead. |
| 649991 | TE-75558 | Fixed an issue wherein the Overtime was not calculated upon submission. |
| 898842 907819 |
TE-82138, TE-82968 | Group managers can now successfully transition Timesheets using the Everyone who reports to me View. |
User Defined Fields
| 1028672 | TE-83740 | Improved the performance of saving UDFs. The saving of any item having UDF associations should now be quicker. |
| 888924 | TE-71796 | Improved the performance of the of the Project Budget page. |
| 879834 | TE-81639 | You can no longer inline edit User Defined Fields of type checkbox associated to Milestones from the Milestones list page. |
| 1018864 | TE-83537 | Fixed an issue wherein an error message triggered upon attempting to modify the Project Start Date if a Booking without Allocation exists outside of the new date. |
Workflows
| 1024176 | TE-83633 | Fixed an issue with Workflows whereupon attempting to delete some out-of-the-box Notifications resulted in an error. |
Work Processes
| 904478 | TE-82345 | Fixed an issue with Processes, wherein the User Defined Fields tab was empty. |
