PSA 2022 R1.1.1 - Release Update
Below is a summary of the main issues addressed by this release.
Note: This page may be updated as new information becomes available. Visit regularly for the latest updates.
Financial
1049012 TE-84287 You can now successfully post Invoices containing only Money Charges without having to close the Timesheet Period.
New Timesheet
1053899 TE-84420 Upon accessing new My Timesheet through Timesheet Manager, the user's display name is now formatted as Last Name, First Name.
1052757 TE-84418 Fixed an issue wherein selecting a different Phase while picking an Assignment resulted in the Phase to revert to the default option upon saving.
1053468 TE-84518 New Timesheets are now properly respecting their Closed/Open Period status.
Caution: The logic determining whether a Timesheet is in a Closed or Open Period has been modified to now only consider the Start Date of the Timesheet rather than its entire span.
Notifications
1058790 TE-84619 Fixed an issue with Invoice Notifications wherein the Notification was not being sent to Client Contacts when the email was a semi-column delimited list of Email addresses.
1050956 TE-84294 Project Workflow Notifications are now sent to specified Email Addresses as expected.
1057552 TE-84579 Soft Booking Notifications are now sent to specified Email Addresses as expected.
Reporting
1043877
1046505
1048994
1051378
TE-84269 Fixed an issue with RDLC Reports whereupon previewing a report which has no parameters resulted in the report displaying in only a small portion of the viewing area.
Timesheet Manager
1053132 TE-84359 Fixed an issue with Timesheet Manager whereupon applying a Filter based on a Workflow State Attribute was returning no results.
Upland Analytics
1047540 TE-84261 Fixed an issue with the Upland Analytics Expense Data Source, wherein under certain conditions, some reports took a long time to load.
Work Breakdown Structure (WBS)
1053086
1053686
TE-84356 Fixed an issue with Project Overview, wherein the PO Line items were missing from the PO Line Items tab.
