PSA 2022 R1.0 - Resolved Issues
Below is a summary of the main issues addressed by this release.
2022.01.20.2022R1.0.V2.EB
Note: This page may be updated as new information becomes available. Visit regularly for the latest updates.
API/SDK
1186469 TE-88312 Fixed an issue wherein Users updated via the API with an invalid User Type were not listed within the Users List page.
Automation
1149367 TE-87343 Fixed an issue wherein the Process PO Notification Automation Service was failing if a Client PO line item (Name) exceeded 100 characters in length.
Cost/Billing
1190592 TE-88203 A confirmation message is now displayed when attempting to create a Recurring Billing Rule with an End Date that is later than its Task End Date.
Expense Manager
1151870 TE-87374 The Expense Report Process Date column within the Expense Manager now displays the date only when the Expense Report is posted in an Expense Payable Batch.
#1187401 TE-88309 For Concur Imported Expense Reports, the Expense Report Process Date column within the Expense Manager now displays the date when the Expense Report was imported.
Financial
1151772 TE-87891 Fixed an issue wherein, flagging an Invoice to Use Project Contact, was not setting the Billing Contact correctly.
Financial Planner
1134516 TE-87156 Fixed an issue whereupon modifying a Financial Planner Template to display the Total Actual instead of the Running Total, then accessing the associated Financial Planner resulted in the Running Total label to be displayed instead of the Total Actual.
1131196 TE-87032 The Recognizable Revenue now considers the non-labor Amounts when:
• The option Calculate recognizable revenue for actual period is selected.
• The Compute POC based on Cost and Calculate recognizable revenue for actual period are selected.
• When no labor hours are present during the period.
Global Search
1151943,
1155202,
1156897
TE-87415 When searching for Projects through the Global Search, the results now return the correct Projects when Users Project Scoping has been implemented.
Integration
1187401 TE-88309 The Expense Report Process Date column within the Expense Manager now displays correct Expense Report imported from Concur.
Notifications
1135363 TE-87046 Leave Request Age-Based Notifications are now sent to specified recipients as expected.
Organization Breakdown Structure (OBS)
1150373, 1151691, 1155126 TE-87371 Improved the User List performance for a scoped User, when trying to select a User to Impersonate.
Security
1172949 TE-88064 Fixed an issue with Password Reset wherein a Runtime Error message was being triggered upon trying to modify the Password containing some special characters.
Reporting
1153119, 155107, 1156206 TE-87461 Users having numeric values as their Logon name can now access Upland Analytics as expected.
1153879 TE-87681 Filtering the Effective Date Field to Today now displays the expected results.
Resource Management
1150948 TE-87373 Fixed an issue with the Work Plans wherein the Sort Order of the View was incorrect when EAC was not enabled.
Note: If EAC is enabled for the View, the sorting order is as follows: Booking Type > Name > Task name.
1153077 TE-87403 The values of the Workplan (Hrs) KPI is now updated immediately upon adding/modifying a Booking.
1164026 TE-87771 Fixed an issue whereupon entering a Forecast Adjustment value between -1 and 1 resulted in an error.
1176742, 1176807 TE-88051 Improved the performance when selecting Booking Attributes from the Setup page.
1169648 TE-88126 When replacing a Role based booking with a User, the system now automatically removes any Booking Allocations prior to a user’s Hire Date.
1187380 TE-88289 Fixed an issue wherein an error message was being triggered upon choosing to show more than 25 records for the Matching Resources.
1188630 TE-88310 You can now successfully drag a booking from one cell to another.
Timesheet
1150561,
150659,
1158008
TE-87350,
TE-87643
When picking an Assignment in my Timesheet, the auto-selection and filtering logic is now working as expected.
1150971 TE-87388 Fixed an issue whereupon the tool tip containing the list of Assigned Users was not properly displaying when the Timesheet was in a State having a name containing special characters.
1192054 TE-88441 When a Leave Time within the Template is not flagged to Display in Timesheet, the entire Assignment row is now Read-only as expected.
User Defined Fields
1166873,
1167411,
1167412,
1152317
TE-87842,
TE-87848,
TE-87410
Fixed some display issues with User Defined Fields in Project Edit.
Work Breakdown Structure (WBS)
1150227 TE-87338 Fixed an issue wherein an error was produced while loading the Assign Users page if some Users were not in logged User's Scope.
1190018 TE-88348 The formatting of User Name within the left and right panels of the Assign Users page is now consistent to read Last Name, First Name. Furthermore, the Assign All button now functions as expected.
1187380 TE-88570 Fixed an issue with the Assign Users page whereupon assigning a User would redirect the logged user to page 1.
1203371 TE-88802 Fixed an issue with Work Item Workflows, wherein a required User Defined Field associated to a Workflow triggered an error message upon trying to save a Work Item Entry belonging to a different Workflow.
