PSA 2023 R2.0 - Product Enhancements
Below is a summary of the features included in 2023 R2.0.
2023.05.17.2023R2.0.V1.EB
Note: This page may be updated as new information becomes available. Visit regularly for the latest updates.
Expense
Financial Planner
Integration
Leave Request
Mobile
Timesheet
Rate Cards
A Rate Card is a new module where you can create standard Billing rates or price lists based on Roles. Rate Cards enable simplified management of sets of Billing Rates associated with Roles in your Projects.
A typical use case is to create a Rate Card at the system level to store hourly Billing rates/price list defined for a Role. As a project manager you can then select the relevant Rate Card for a customer's Projects and customize it as needed. The Billing Rates will be automatically applied to Resources with matching Roles to calculate accurate expected and actual Revenues.
Rate Cards are particularly useful for consulting firms, agencies and contractors where billable projects are worked on by resources with different skills, experience, location, and availability. As such, resources with different roles are billed at different rates, and having multiple Rate Cards provides the flexibility for accurately defined roles and rates.
Rate Cards are ideal for organizations where standardized Billing Rules are used for Roles meaning that you do not set individual billing rates for Team members. Instead, the rates billed will be determined by the Team member's Role on the project. As an example, all Designers have the same billing rate regardless of the user assigned to the role.
Note: Rate Cards take precedence over all other Rate Rules and apply only for Billing.
Resource Management
Security
Timesheet Manager
Timesheet Templates
Upland Analytics
User Defined Fields
User Experience Enhancements
The improved tables, buttons, options, Dialog Boxes, Icons and Search all fall in line with the upgraded standards that have already been applied on several pages during the recent releases to enhance user experience and establish consistency across the application.
Although most of the features remain the same, the appearance and usability have been significantly improved to enhance your overall experience.
Client Edit Renovation (TE-87590, TE-87917, TE-88425, TE-89887, TE-5777)
The Client Edit pages are now structured in the same familiar format already in use in other areas of the application. Although most of the features remain the same, the appearance and usability have been significantly improved to enhance your overall experience.
For further details refer to: Configuring Clients (WBS)
Financial Setup Renovation (TE-89122, TE-89573)
The Financial System pages are now structured in the same familiar format already in use in other areas of the application. Although most of the features remain the same, the appearance and usability have been significantly improved to enhance your overall experience.
For further details refer to: Financial System Setup
User Edit Renovation (TE-88080, TE-88082, TE-89867)
The interface for creating and editing users has been redesigned with a new look and improved navigation. There are now two tabs: Settings and Work Plan.
There are now six main sections on the left-hand side of the Settings tab: Settings, Employment, Entry Options, Financial, Others, and Integration. Each of these is further divided into components.
For further details refer to: Configuring a User (OBS)
Other
Users
Deprecated/Unsupported Functionality
