Move or Copy File(s) or Folder(s)
Within File Manager, you can copy a report or folder. This topic details how to copy a file; however the process is similar when copying a folder (the only difference being you select the folder rather than file in step 3.)
1. Access File Manager
Access the File Manager:
- Click the Analytics Settings button from the Main Menu Bar.
- Then select File Manager from the menu.
2. Navigate to the folder
- Navigate to the folder where you wish to Copy File(s) or Folder(s) by clicking the folder name in the Directory Listing section.
If you want to jump to a folder that is buried in several other folders, use the Directory Listing. You can click the black triangle next to any folder name to see any folders within that directory, and navigate to the desired folder. Clicking on a folder will display its contents in the File Listing section.
3. Move/Copy File
- Select the file you wish to Move/Copy.
- Click the Move/Copy button.
4. Select Your Destination
- Select the folder where you want to move or copy your folder or file. Note that the selected folder will be displayed against Destination in bold.
- Click Move or Copy.
5. Confirm Copy or Move
- Click Yes to confirm the copying or moving of file(s) or Folder(s).
6. View your Changes
- Navigate to the folder where the file(s) folder(s) were moved/copied to and view your changes.
Menu
