Download a List of Data Sources
You can download one of the following:
To download the complete list of all available data sources:
  1. Click Analytics Settings on the Main Menu Bar.
  2. Select Data Sources from the menu. The Data Sources page displays a list of all available data sources.
  3. Click one of the following options on the main menu:
    • Download CSV: Download the list of all available data sources as a comma separated values (.CSV) file.
    • Download Excel: Download the list of all available data sources as an Excel (.xlsx) file.
    • Download PDF: Download the list of all available data sources as a Portable Document Format (.PDF) file.
To download a filtered list of data sources:
  2. Select Data Sources from the menu. The Data Sources page displays a list of all available data views.
  3. Click Expand Filter to access the Filters box.
  4. Enter any of the following information:
    • Key: Type the Key which was generated automatically when creating the data source.
    • Title: Type the name of the data source.
    • Description: Type a description for the data source.
    • Last Modified By: Displays the name of the person who last modified the data source. Click to select a name from the available list.
    • Last Modified On: Select a date range when the data source was last modified.
  5. Click Search to apply the search filter on the list of all available data sources. The list is filtered to contain only the data source(s) you want to download.
  6. Click one of the following options on the main menu:
