Create a Report
Note: Data sources in this step are provided for example only. Your data sources will depend on the modules licensed and the permissions granted. For more information, see Data Sources/Views.
- Click the Add report name box and type the name for your report.
- Do the following to add fields to the report:
- All Fields
- Dimensions
- Measures
- Date
- Drag and drop the fields to add to the report from the Fields list to the Layout section.
- Click
to add a pivot. For more information, see Add a Pivot. - Optional: Click
to view the available Report Settings options: - Show Subtotal: By default, None is selected which means the report will not display a subtotal:
- First: A subtotal will display in the first column of your report.
- All: A subtotal will display for every numerical column of your report.
- Show Total: By default, Yes is selected. If you select No, a total will not be displayed in your report.
- Optional: Click Preview to preview your report. Your report displays in View Mode.
To send the report or graph/chart offline in an email.
To stop loading and abort the report or graph/chart.
To continue waiting and view the report or graph/chart.- Click Save to open the Save context menu
- Save: Selecting this option will save the report without exiting the report edit page.
- Save as copy: Selecting this option will save a copy of the report. You will need to rename the report in the Navigation Menu.
- Save & Close: Selecting this option will save the report and close the report edit page. The report will then run.
- Save & send by email: Selecting this option will save the report and close the report edit page. A modal window will then give you the options to send the report. For more information, see Email a Report.
- Save & Create new: Selecting this option will save the report and close the report edit page giving you the option to create a new report.
Note: You must add at least one filter.
Note: Click Save to save your changes or Cancel to return to your Report Layout page.
Note: You can preview your report at any time by clicking on the Preview button. No Data Available displays when there is no data retrieved/found.
Click one of the following:
