Delete a Graph/Chart
You can delete an existing graph/chart, provided you have the access rights to do so.
Note: The delete functionality is only available to you if you are the Master Administrator or the Report Creator.
Caution: When a graph/chart is deleted, all subscriptions to the graph/chart are also deleted.
- Do one of the following to delete an existing graph/chart:
- From the Navigation menu, click
located on the right of the graph/chart name you want to delete and click Delete. A confirmation window displays. - From an existing graph/chart, open the Main Menu bar and click
When the graph/chart has dependencies or is a widget on a dashboard they display in the dialog box.
- Do one of the following:
- Click the dashboard hyperlink to open the dashboard that contains the widget.
- Click Delete to permanently delete the graph/chart.
- Click Cancel to return to the previous page.
Note: If you delete a graph/chart that is a widget on a dashboard, the graph/chart is deleted from the dashboard.
