Create a Line Graph
Line graphs display your data within a series as points connected by straight line segments on two axes and helps determine the relationship between two sets of values.
Use Line graphs to track changes over short and long periods of time. When smaller changes exist, line graphs are better to use than bar graphs. Line graphs can also be used to compare changes over the same period of time for more than one group.
- X-Axis Group: one non-numeric field to define the main category on the x-axis (horizontally).
- Data Points: one non-numeric field to define the different points in the line(s), in relation to the data set on the y-axis.
- Y-Axis Data Set: an unlimited number of numeric fields to define the values on the y-axis (vertically), in relation to the data points.
To create a Line graph:
- All Fields
- Dimensions
- Measures
- Date
- Click
Click one of the following:
