About Received Faxes and Default RuleSets
The
- Inbound messages against the Received Faxes Rulesets
- Outbound messages against the Default RuleSets
Received Faxes RuleSets
The Received Faxes RuleSets specify the following parameters.
- The criteria identifying what rule to match.
- The actions to perform.
- Any failover actions, if needed.
Accessing Received Faxes RuleSets
To access the Received Faxes RuleSets
- Start the Server Administrator.
On the Start menu, click Upland AccuRoute >
- Select RuleSets > Received Faxes. The details pane lists the default Received Faxes rules created when you installed the server.
Default RuleSets
The Default RuleSets specify the following parameters.
Accessing Default RuleSets
To access the Default RuleSets
- Select RuleSets > Default. The details pane lists the Default rules created when you installed the server.
Note: You can also create custom User RuleSets or modify or delete existing rules, as needed. For information on how to create a new rule, see User RuleSets.
