About User RuleSets
With User RuleSets, you can create custom rules for the
Creating User RuleSets
You can create User RuleSets to the following destinations.
- Start the Server Administrator.
On the Start menu, click Upland AccuRoute >
- On the Server Administrator tree, select and expand RuleSets, if necessary.
- Right-click Users. The Properties shortcut menu appears.
- Select New > Route to Connector. The Criteria dialog box appears.
- Select Email on the Destination type drop-down list.
- Type user@testdc.net in the Matches box.
- Click Next. The Deliver dialog box appears.
- Select a connector on the Connector drop-down list.
- Select a format; for example, PDF on the Format drop-down list.
- Click Next. The rule name appears on the Complete dialog box.
- Click Finish. The rule appears in the User details pane.
- Select New > Route to Embedded Directive Manager. The Criteria dialog box appears.
- Click Next. The Embedded Directive box appears.
- Select Scan document(s) for Embedded Directive or choose other options, if necessary.
- Select New > Route to Failure. The Criteria dialog box appears.
- Select New > Route to Lookup. The Criteria dialog box appears.
- Select New > Route to Advanced Routing. The Rule Properties > General dialog box appears.
Type a rule name in the Name box.
- Select the Actions tab.
- Click Add. The Select Rule Template to Add dialog box appears.
- Click Route to Connector and the Select button. The Actions workflow appears.
- On the Actions workflow, go to Route to Connectors, and select Deliver {Not Configured}.
Note: Important! You can associate up to five criteria with a rule. If you want to set more than five criteria for a rule, create the rule with the first five criteria, make a copy of the rule, add the next five criteria, and so on.
About Received Faxes and Default RuleSets
