The following table lists variables that are available for Routing Sheets. For a list of other variables that can be used in Routing Sheets, see List of template variables (in alphabetical order).
| Variable | Description |
| %ROUTINGSHEET_TITLE% | Title of the Routing Sheet created by the end user |
| %OMEDID_BARCODE% | The barcode image is replaced with this variable |
| %SENDER_EMAIL% | Sender's email address |
| %ROUTINGSHEET_DATE_CREATED% | Date the Routing Sheet was created |
| %ROUTINGSHEET_DATE_EXPIRES% | Date the routing will expire (if applicable) |
| %ROUTINGSHEET_SINGLE_USE% | Indicates the Routing Sheet is single use |
| %EMAIL_DESTINATION.1% | First email recipient’s email address (The number indicates how many email recipients to list.) |
| %EMAIL_DOCTYPE.1% | Final form to be sent to the first document management location |
| %PRINT_DESTINATION.1% | First printer recipient |
| %FAX_DESTINATION.1% | First fax recipient |
| %UNC_DISPLAY_DESTINATION.1% | First network folder recipients |
Creating Routing Sheet Templates Guidelines
