Reauthorizing Access to a NetDocuments Account
For Upland AccuRoute Desktop Client and NetDocuments users only
Issue: Desktop Client and NetDocuments Error Message Appears After Upgrade
The following error message appears when attempting to profile a document after completing a Server and Desktop Client  upgrade.
Upland AccuRoute in conjunction with NetDocuments support the OAuth (Open Authorization) New Refresh Token Issuance for enhanced security and flexibility. An upgrade to the Server, Desktop Client, and Queue from a previous installation will require a reauthorization of NetDocuments.
See About OAuth New Refresh Token Issuance for more information.
Tip/Solution: NetDocuments Reauthorization for Administrators
You must reauthorize the NetDocuments account if you have completed an AccuRoute Server, Desktop, and Queue upgrade.
To reauthorize the NetDocuments account
  2. Expand the Server Administrator tree;  if necessary,  and select Connectors.
  3. Select the NetDocuments on the Server connector. The NetDocuments on the Server Properties dialog box appears.
  4. Click the Advanced tab.
  5. Click Configure. The NetDocuments Login Configuration dialog box appears.
  6. Ensure the correct NetDocuments vault is selected and click Authorize. The NetDocuments Authorize/Login dialog box appears.
  7. Type your Administrator username and password in the appropriate boxes and click Login.
  8. Click Allow.
  9. Click Finish.
Tip/Solution: NetDocuments Reauthorization For Desktop Client Users
Desktop Client user must reauthorize their NetDocuments account after a Server, Desktop Client, and Queue upgrade.
  1. Start the Desktop Client.
  2. Select Tools >  Configure DMS > NetDocuments. The NetDocuments Login Configuration dialog box appears.
  3. Ensure the correct NetDocuments vault is selected and click Authorize. The NetDocuments Authorize/Login dialog box appears.
  4. Type your Desktop Client username and password in the appropriate boxes and click Login.
  5. Click Allow.
  6. Click Finish.
Note: This resolution only applies to users that are upgrading from a previous installation.
