Control File Keywords List
The following table lists the control file keywords.
Keyword |
Description |
Value |
This keyword allows the control file to specify that the attachments are to be treated as batch processing by the Embedded Directive Manager. It works with Guidelines: This property should be used to indicate the document contains one or more routing sheets, and that the job should be split at each routing sheet and treated as a number of separate jobs. Example: # |
TRUE|FALSE TRUE to indicate the job is a batch. FALSE to indicate the job is not a batch. |
This keyword allows the control file to specify the number of expected jobs to be found in the Guidelines: This property should be used if This property can be used in a virtual control file, but as the batch count will change with every submission, it would require editing the virtual control file every time a new batch is submitted. An alternative would be to set up multiple scan folders that correspond to the batch count and put a virtual control file in each folder. For example, a folder named 1Batch could contain a virtual control file using the property #ACCUROUTE_BATCH_COUNT_1, while a folder named 2Batch could contain a virtual control file using the property #ACCUROUTE_BATCH_COUNT_2, etc. Example: #ACCUROUTE_BATCH_COUNT 10 |
Integer value |
#ACCESS_CODE |
This keyword indicates the sender's personal access code used to send faxes. It works with Guidelines: The value for this keyword should match the value in a dialing rule on the server. If it does not, the server processes the fax, but the telephone system your company uses might prevent delivery. Example: #ACCESS_CODE 1234 |
Sender's personal access code. |
#APPROVAL |
This keyword determines whether a fax requires approval before the server can deliver it. It works with the Guidelines: If all the sender's faxes must be approved, then this keyword must be included in the control file with a YES or TRUE value. If approval is optional for the sender, all possible values are valid. If the sender or server has not been configured for approval, the connector ignores this keyword. Example: #APPROVAL YES |
TRUE|FALSE |
#ATTACHMENT |
This keyword indicates the files that should be sent as part of the document or fax. It works with the Guidelines: This keyword is required in the control file if you are sending a document or fax via the server. You can select any file in a supported file format. Examples: #ATTACHMENT filename.txt |
The file name of a document if the document is copied to the Filescan folder with the control file. Note: The Filescan connector removes the file from the Filescan folder. The path to a document if the document is not copied to the Filescan folder. The path to the document must be a fully qualified file path, such as: \\computer\folder\filename or G:\\folder\filename Note: The Filescan folder might be located on a different computer than the computer where you create the control file. In this instance, the example G:\\folder\filename means that the attachment is located on the G drive of the computer where the Filescan folder is located. |
#BILLING_CODE |
This keyword indicates the billing code associated with a document or fax. It works with the Example: #BILLING_CODE 55512347 |
Integer value |
#COMMENTS |
This keyword indicates the comments that should appear on the cover page of the document or fax. It works with the Example: #COMMENTS Hi Bill, this is the document I promised to send. Call me anytime with questions. Thanks again for your help. |
String value |
#COVERPAGE |
This keyword indicates the cover page style that should be included with the document or fax. It works with the Guidelines: You can select a different cover page style for each recipient, or select one for all recipients. If you want to use one cover page style for all recipients, position the keyword before indicating any recipients. If you want to use a different cover page style for each recipient, include the keyword after indicating each recipient. For cover page templates with an OMTPL extension, do not include the file extension. For all other template files such as RTF or HTM, include the extension. Examples: #COVERPAGE salescoverpage |
String value Note: All cover page template names are stored on the server. |
#DESTINATION |
Important!This keyword is required in all control files. If you are creating a control file for an This keyword indicates the destination address for a recipient. It works with the server, and can be used with Filescan and SMTP connectors. Guidelines: Use the following formats: #DESTINATION [Destination Type] [Destination Information] Possible destination types include:
Note: If no destination type is indicated, the Filescan connector interprets the destination as a fax number. Do not use spaces in a destination address. Punctuation marks including hyphens, backslashes, and periods are valid. Examples: #DESTINATION EMAIL ksmith@company.com |
Fax number (interger value) or email (string value) of the recipient. |
#DESTINATION EMBEDDEDDIRECTIVE <Embedded Directive string> |
This keyword indicates an Embedded Directive that resides on the Guidelines: When this keyword is used in a control file for traditional Filescan, the embedded directive provides the server with delivery instructions for a document or fax. When this keyword is used in a control file for virtual mode Filescan, the Embedded Directive provides the server with delivery instructions for all documents and faxes copied to the Filescan folder. (The Filescan connector does not delete the control file from the Filescan folder when virtual mode has been configured.) Do not use the #DESTINATION EMBEDDEDDIRECTIVE keyword with the #DESTINATION keyword. Examples: #DESTINATION EMBEDDEDDIRECTIVE KSNP-XXSYXSER-WDAD-PDXD-BECP-DNHXKATTHBRN |
String value |
#NOTIFY |
This keyword indicated the notification setting for a document or fax. It works with the server, and can be used with Filescan and SMTP connectors. Guidelines: Use the following format when indicating the notification setting: #NOTIFY [notification type] [notification destination type] [destination information] Valid notification types are:
Valid notification destination types are:
Examples: #NOTIFY SUCCESS FAX 123456789 |
String value containing notification settings |
#OVERRIDE token value |
This keyword allows you to specify any valid Filescan token/value pair as an override to an Embedded Directive submission. The Embedded Directive Manager will take these values and override the properties on the resultant jobs specified by the Embedded Directive. It works with Guidelines: This keyword is only applied for jobs that are sent to the Embedded Directive Manager for processing as an Embedded Directive submission. The most common use of this keyword is to allow the user to override the previously chosen billing_code or prDeliveredDocumentName in the Embedded Directive for each recipient, that is used by the Embedded Directive Manager. Example: #OVERRIDE BILLING_CODE 123^333^444 This would override the billing code for each job in the Embedded Directive. |
The token can be any valid Filescan control token (the value depends on the token chosen). |
#prDeliveredDocumentProcessing |
This keyword determines whether the server should override the attachment handling instructions specified in the connector rule. Guidelines: This keyword pertains to advanced functionality that can merge or split message attachments before they are queued for delivery by an outbound connector. It is optional. When used, it overrides the attachment handling instructions specified in the connector rule and either merges all message attachments or splits them based on a page count or file size policy. Example: #prDeliveredDocumentProcessing 0 This property is set to 0 so that all message attachments will be merged into a single attachment before the message is passed to the outbound connector for delivery. No additional attachment handling instructions are required for this example. |
Value can be:
#prDeliveredSplitProcessing |
This keyword provides instructions on how message attachments should be split. Guidelines: This keyword pertains to advanced functionality that can merge or split message attachments before they are queued for delivery by an outbound connector. It is valid only when used in conjunction with variable prDeliveredDocumentProcessing, and the value of this variable is set to 1. This variable requires prDeliveredSplitArgument variable. Example: #prDeliveredDocumentProcessing 1 In this example, prDeliveredDocumentProcessing is set to 1 so that all message attachments will be split according to a page count policy or file size policy. prDeliveredSplitProcessing is set to 1, and this specifies that all message attachments will be split according to a file size policy. prDeliveredSplitArgument is set to 2048 so that message attachments will be split into attachments that are no larger than 2048KB (2MB). |
#prDeliveredSplitArgument
This keyword provides instructions on how message attachments should be split. Guidelines: This keyword pertains to advanced functionality that can merge or split message attachments before they are queued for delivery by an outbound connector. It is valid only when used in conjunction with prDeliveredDocumentProcessing and prDeliveredSplitProcessing.
Example: #prDeliveredDocumentProcessing 1 |
Integer value The integer value represents a page count when #prDeliveredSplitProcessing is set to 0. The integer value represents file size when #prDeliveredSplitProcessing is set to 1. |
#prDeliveredSplitMergeFirst
This keyword provides instructions on how message attachments should be split. Guidelines: This keyword pertains to advanced functionality that can merge or split message attachments before they are queued for delivery by an outbound connector. It is valid only when used in conjunction with prDeliveredDocumentProcessing and prDeliveredSplitProcessing. Example: #prDeliveredDocumentProcessing 1 In this example, prDeliveredDocumentProcessing is set to 1 so that all message attachments will be split according to a page count policy or file size policy. prDeliveredSplitProcessing is set to 1, and this specifies that all message attachments will be split according to a page count policy. prDeliveredSplitArgument is set to 10 so that message attachments will be split into attachments that are no longer than 10 pages. prDeliveredSplitMergeFirst is set to 0 so that all message attachments will be merged into a single attachment before it is split according to the page count policy. |
0 | 1 Use 0 to merge all message attachments before splitting them according to the specified page count or file size policy (The merge order is based on the order in which the user originally added attachments to the message). Use 1 to split message attachments individually according to the specified page count or file size policy (This is the default value when this property is not set.) |
#prDeliveredSplitFilenameTemplate
This keyword identifies the filename template that should be used for all message attachments that are processed using the message attachment handling override. (An override occurs when prDeliveredDocumentProcessing is set to 0 or 1). Guidelines: When the message attachment handling configuration specifies that attachments are to be split based on a page count policy or file size policy, the string must include %INDEX% to label the respective parts of each attachment and %ATTACHMENT_INDEX% to label each attachment. If multiple attachments are merged into a single attachment before it is split, %ATTACHMENT_INDEX% can be omitted. Example: #prDeliveredDocumentProcessing 1 In this example, prDeliveredDocumentProcessing is set to 1 so that all message attachments will be split according to a page count policy or file size policy. prDeliveredSplitProcessing is set to 1, and this specifies that all message attachments will be split according to a page count policy. prDeliveredSplitArgument is set to 10 so that message attachments will be split into attachments that are no longer than 10 pages. prDeliveredSplitMergeFirst is set to 0 so that all message attachments will be merged into a single attachment before it is split according to the page count policy. prDeliveredSplitFilenameTemplate is set to Doc%ATTACHMENT_INDEX%Part%INDEX%%RECIP_NAME% so that a resulting attachment might look similar to the following: Doc1Part3AnnaBarger.PDF |
The following variables have been qualified for use with this variable:
#prDocumentStampName |
This keyword provides the Document Stamp name you want to apply when used in routing rules or from FileScan. Guidelines: You must include the name of the Document Stamp as it was entered when configured by the Administrator. The name is not case-sensitive. Examples: To create the appearance of a fax on an internal document sent to a printer (not via actual fax), one could mimic the look of the line of text typically at the top of a fax page by using a Document Stamp instead. While Document Stamps do not offer the transparency of a watermark, another example of their use would be to apply the term "DRAFT" or "Confidential" diagonally across a page. You can apply a transparent image, but any variable or text used will appear in full opacity. |
Document Stamp name |
#PREVIEW_REQUIRED
This keyword indicates that preview of the composed document or fax has been requested. It works with the Guidelines: You must include the sender's e-mail address. When a preview of the document or fax is available, the server sends a notification message to the sender's e-mail address. (The notification message contains a link to the preview in the Web Client.) Example:#PREVIEW_REQUIRED YES |
YES or Y to request preview. |
#prGroupFolderUseSuppliedCredIfAvailable |
This keyword provides instructions on whether or not alternate credentials are provided. Example: #SENDER_EMAIL Abc_Co@company.com |
0 | 1 Use 0 to not apply the alternate credentials provided and not deliver the file to FTP. Use 1 to apply the alternate credentials provided and deliver the file to FTP |
#PRIORITY
This keyword indicates the priority associated with a document or fax. It works with the Guidelines: When the control file does not include this keyword, the document or fax is delivered with normal priority. Example:#PRIORITY LOW |
HIGH | NORMAL | LOW |
#RECIPIENT
This keyword indicates the beginning of a recipient section. It works with the Guidelines: This keyword is required in all control files. Example: ;Recipient 1 |
None |
#RECIP_NAME
This keyword indicate the recipient's name. It works with the Guidelines: Use this keyword in the recipient section, following the #RECIPIENT variable. Example: #RECIPIENT |
String value containing the recipient's name |
SECURE_DELIVERY
This keyword indicated whether secure delivery is required for the fax. It works with the Guidelines: Secure delivery must be enabled on the server if you want to send a fax with secure delivery. If secure delivery has not been enabled on the server, the Filescan connector ignores the keyword and sends the fax immediately. Example: #SECURE_DELIVERY YES |
YES | TRUE | No | FALSE | Use YES, TRUE to request secure delivery. Use NO, FALSE or do not use the variable if you do not want to request secure delivery. |
#SEND_AFTER
This keyword indicates the date and time when the server should attempt to send the fax. It works with the Guidelines: Use one of the following formats:
Example: #SEND_AFTER 03/26/2002 12:30:00pm |
String value with the date and time when the server should attempt to deliver the fax |
#SENDER_BUSINESS_ADDRESS
This keyword indicates the sender's business address. It works with the Guidelines: If the document or fax requires a cover page, and the cover page template has been configured to display the sender's business address, the sender's business address appears on the cover page. Example:#SENDER_BUSINESS_ADDRESS 14 South St. |
String value containing the address |
#SENDER_BUSINESS_CITY
This keyword indicates the city associated with the sender's business address. It works with the Guidelines: If the document or fax requires a cover page, and the cover page template has been configured to display the city associated with the sender's business address, the city appears on the cover page. Example:#SENDER_BUSINESS_CITY Newton |
String value |
#SENDER_BUSINESS_FAX_NUMBER
This keyword indicates the city associated with the sender's business fax number. It works with the Guidelines: If the document or fax requires a cover page, and the cover page template has been configured to display the sender's business fax number, the fax number appears on the cover page. Example: #SENDER_BUSINESS_FAX_NUMBER 603-555-1234 |
String value containing the fax number |
#SENDER_BUSINESS_STATE
This keyword indicates the state associated with the sender's business address. It works with the server, and can be used with Filescan and SMTP connectors. Guidelines: If the document or fax requires a cover page, and the cover page template has been configured to display the state associated with the sender's business address, the state appears on the cover page. Example:#SENDER_BUSINESS_STATE NH |
String value containing the state |
#SENDER_BUSINESS_ZIPCODE
This keyword indicates the zip code associated with the sender's business address. It works with the Guidelines: If the document or fax requires a cover page, and the cover page template has been configured to display the zip code associated with the sender's business address, the zip code appears on the cover page. Example:#BUSINESS_ZIPCODE 03103 |
String value containing the zip code |
#SENDER_COMPANY
This keyword indicates sender's company name. It works with the Guidelines: If the document or fax requires a cover page, and the cover page template has been configured to display the sender's company name, the company name appears on the cover page. Example:#SENDER_COMPANY XYZ Corporation |
String value containing the company name |
#SENDER_DEPARTMENT
This keyword indicates sender's department name. It works with the Guidelines: If the document or fax requires a cover page, and the cover page template has been configured to display the sender's department name, the department name appears on the cover page. Example:#SENDER_DEPARTMENT Marketing |
String value containing the department name |
#SENDER_DISPLAY_NAME
This keyword indicates sender's display name. It works with the Guidelines: If the document or fax requires a cover page, and the cover page template has been configured to display the sender's display name, the display name appears on the cover page. Example:#SENDER_DISPLAY_NAME John Smith |
String value containing the display name |
#SENDER_EMAIL
This keyword indicates sender's e-mail address. It works with the Guidelines: The server uses this email address for notification messages. This keyword is required in all control files. Example:#SENDER_EMAIL janesmith@company.com |
String value containing the email address. |
#SENDER_NAME
This keyword indicates sender's name. It works with the Guidelines: If the document or fax requires a cover page, and the cover page template has been configured to display the sender's name, the name appears on the cover page. Example:#SENDER_NAME John Smith |
String value containing the name |
#SENDER_WEBADDRESS
This keyword indicates sender's web site address. It works with the Guidelines: If the document or fax requires a cover page, and the cover page template has been configured to display the sender's web site address, the web site address appears on the cover page. Example:#SENDER_WEBADDRESS=http://www.xyzcorp.com |
Web URL |
#SUBJECT
This keyword indicates the subject of the outbound document or fax. It works with the Guidelines: If the document or fax requires a cover page, and the cover page template has been configured to display the subject (%SUBJECT%), the subject appears on the cover page. Additionally, if the server generates a notification message pertaining to the document or fax, and the notification template has been configured to display the subject (%ORIGINAL_SUBJECT%), the subject appears in the notification message. Example: #SUBJECT Proposed estimates for contract |
String value containing the subject |
#USE_MYACCUROUTE |
This keyword sets the flag that identifies the job as a My Guidelines:This value is used to indicate that the job should use the Embedded Directive that is specified in the sender's My
Examples: #USE_MYACCUROUTE TRUE |
TRUE | FALSE | ORIGINATOR |DESTINATION Use TRUE, ORIGINATOR or DESTINATION to indicate that the job is a MyAccuRoute submission. Use FALSE to indicate that the job is not a MyAccuRoute submission. The flag is used by the Embedded Directive Manager. |
