Creating Server to Server Routing Rule
You can create a Server to Server routing rule by using the Server Administrator > Rules node.
To create a Server to Server routing rule
  1. Start the AccouRoute Server Administrator.
    Start > All Programs > Omtool > AccuRoute Server > AccuRoute Server Administrator
  2. Expand Rules in the console tree.
  3. Right-click on Outbound and select New > Rule. The Specify the Criteria for this Rule dialog box appears.
  4. Click Add and add one or more criterion you want to use for this rule:
    • From the list on the Add Rule Criteria dialog box , select a criterion you want to add to this rule and click Next.
    • On the Items to Match dialog box , provide the appropriate information about the criterion you selected so that the AccuRoute Server can determine which messages to route by this rule and click Add.
    • Click Finish. The Specify the Criteria for this Rule dialog box appears.
  5. Repeat step 4 to add additional criteria if necessary, and click Next on the Specify the Criteria for this Rule dialog box when you finish adding criteria. The Specify the Actions to take for this Rule dialog box appears.
Note: When you add more than one condition, it becomes an AND statement, meaning that all conditions must be met for a message to match this rule. The more conditions you add, the more specific the rule becomes and the fewer messages will qualify for routing by the rule.
  1. Click Add and add one or more actions you want the AccuRoute Server to perform with messages that match this rule:
    • From the list box on the Add Rule Action dialog box , select Route to Connector and click Next.
    • From the Route to connector drop-down list, select the SSR connector.
    • If you want the AccuRoute Server to omit the cover page template from the fax when it routes it via server-to-server routing, clear Include Template. If you Include Template selected, the cover page is routed with the fax.
    • Select Destination and type the enter the IP address of the AccuRoute Server that has the SSR connector to which you want these messages to be routed.
    • If you want a different cover page sent with messages routed via SSR, select Templateand enter the name of the new template in the text box.
    • Click Finish.
  2. Repeat step 6 to add additional actions if necessary, and click Next on the Specify the Actions to take for this Rule dialog box when you finish adding actions.
  3. On the If any Actions fail do the following dialog box , click Add to add an action for the AccuRoute Server to take if any of the primary actions specified in step 6 fail for any reason:
    • From the list box on the Add Rule on Failure Action dialog box , select the action you want this rule to use. This is the action the AccuRoute Server will perform on messages matching the specified criteria.
    • Click Next. The screen that appears differs depending on the routing action you selected.
    • Follow the instructions on the next screen to define the action you selected and click Finish.
  4. Repeat step 8 to add additional actions if necessary and click Next on the If any Actions fail do the following dialog box .
  5. In the Specify a name for this rule text box, enter a descriptive name for the rule.
  6. Optionally, select the Enable this rule option to enable this routing rule on the AccuRoute Server. If at any time you need to disable this rule, clear your selection.
  7. Optionally, select Stop processing other rules so that messages that match this rule for processing are not processed by the subsequent rules on the AccuRoute Server.
  8. Click Finish.
  9. Order the outbound routing rules as needed.
About Routing Rules
About XeroxScan Connector
About SSR Connector
