About XeroxScan Connector
The XeroxScan connector allows the Upland AccuRoute server to process and deliver documents from a Xerox network scanning device, thus allowing you to leverage content from hard-copy documents. The XeroxScan connector utilizes a scan repository, a shared folder where the Xerox network scanner copies scanned documents. It routinely monitors the scan repository and collects scanned documents.
Note: If you want to set up the XeroxScan connector via Network Fax on the Xerox MFD, refer to the System Administrator Guide for your Xerox MFD, and locate the section on Network Fax. The System Administration Guide is available at http://www.xerox.com. Open the page and click Support & Drivers, and then select your Xerox MFD model.
XeroxScan connector requirements
You must have the following installed and configured before you can install the XeroxScan connector.
  • Upland AccuRoute server with all the required configurations
  • Configuring IIS setup on the server
  • FTP site and a repository
  • Logon account for the Xerox MFD device
  • Enable and configure Network Fax on the Xerox MFD, or create at least one network scanning template that users can select when sending documents through the server.
For instructions on configuring IIS, setting up the FTP site and repository and creating the logon account, see Setup instructions for the XeroxScan Connector.
Upland AccuRoute server only
Additionally, for Upland AccuRoute servers only, you need to configure the following:
  • Configure the XeroxScan connector to include the default destination 222876883 for documents that enter the server via the XeroxScan connector.
  • Create a routing rule directing documents with the destination address above to the Embedded Directive Manager component.
Accessing the XeroxScan connector
To access the XeroxScan connector
  3. Select Connectors. The details pane lists the connectors that are licensed with your server.
  4. Double-click the XeroxScan connector to view its properties.
About Xerox Walk-Up Printing Driver
The Xerox Walk-Up Printing Driver 2.0 enables your AccuRoute or Fax server to print to the IP address of any Xerox multifunction device in the local area network. When this multipurpose driver has been installed, you do not need to install specific drivers for each printer model in the local area network.
This driver is available on your AccuRoute or Fax installation CD in the following directory: \Tools\Xerox Walk-Up Printing Driver\
For instructions on how to install the driver, consult the Embedded Device Client Installation Guide.
Upland AccuRoute Server, Fax and XeroxScan Connector
Adding a XeroxScan Connector
About Xerox Connector Default Destination and Format
Configuring Xerox Connector Defaults
About XeroxScan Connector Network Scanning Templates
Adding a XeroxScan Connector Repository
