Installing Remote Modem Server
A Modem Server is a server that sends and/or receives faxes for the Upland AccuRoute server. It consists of at least one locally installed fax board, Brooktrout System Software / Drivers, and Modem Server software. The server supports multiple Modem Servers, all managed by the connector for Telco on the server. A remote system that hosts a Modem Server is called Remote Modem Server.
The server can run without a local Modem Server, and the environment can have more Telco connectors or fewer Remote Modem Servers than shown in this illustration. The Telco connector can be configured to monitor one Telco share, an intermediary repository for inbound and outbound faxes.
Modem Servers are supported in these configurations:
  • Telco connector with one Modem Server in the LAN
  • Telco connector with multiple Modem Servers in the LAN
  • Multiple Telco connectors, each with one or more Modem Servers in the LAN
Using multiple Telco connectors delivers additional benefits to environments with special faxing requirements:
  • Reduced faxing costs - With multiple connectors for Telco, the server can be configured to deliver faxes using the Modem Server that is closest to the destination which can reduce long distance telephones charges.
  • Failover support - Through rules, the server can be configured to route outbound faxes to one connector for Telco but if delivery fails, the server can route the outbound faxes to another connector for Telco.
  • Increased efficiency - Multiple connectors for Telco provide built-in workload distribution based on the server configuration, the connector for Telco configuration, and rules.
When scaling an environment with additional connectors or components, contact Technical Support. Technical Support can assist you in correctly identifying potential bottlenecks in the system based on workload and other factors. Moreover, Technical Support can provide helpful information on the overall impact of increasing the speed and efficiency of the system. Performance and stability consulting are also available for a fee.
To purchase additional Modem Servers, contact your Account Manager. If a detailed analysis of the environment is necessary, Technical Support may recommend a fee-based consultation.
Installing Remote Embedded Directive Manager
