Viewing Message Properties
Administrators can view and use message properties to troubleshoot and manage messages processed by the Upland AccuRoute Server. Each message has a set of properties that is categorized in the following manner.
  • General lists properties like recipient, email address, routed to, priority, job id, status and more.
  • Attachments lists attachments sent with the message.
  • Job Properties lists job properties associated with the message.
  • Barcodes lists barcodes used with message.
  • Confirmations lists notifications about the message.
In addition, each message has an Activity Log and Journal. The Activity Log shows message activities and server processing time values. The Journal shows message events, errors, and statuses.
You can view message properties by using the Server Administrator > Messages node.
To view message properties
  3. Expand Messages in the console tree. Click In Process or History. The Messages details pane shows the barometers and messages in each queue.
  4. If you want to filter messages that are listed in the details pane, select an option from the View drop-down list.
    You can also filter messages by clicking on the barometer button where the messages reside. For example, if you want to see messages that have been dispatched, click the Dispatch barometer in the In Process folder.
Note: You must select barometers with messages in the queue. A number appears at the top of the barometer when there are messages for you to view.
  1. Right-click on the message whose properties you want to view.
  2. Select Properties from the short-cut menu. The Properties dialog box appears.
  3. Select any of the following tabs.
    • General
    • Attachments
    • Job Properties
    • Barcodes
    • Confirmations
    • Activity Log
    • Journal
Tip: Use the Journal to view any errors that may have occurred during processing. For more information, see Message Properties Journal.
  1. Click Close.
If you are having difficulty locating a particular message, create a custom view using search filter criteria. For instructions, see Creating Custom Views.
Messages In Process
Messages In History
