About Area Code Rules
You can create Area Code rules for the dialing rules associated with the Telco connector. The following information must be specified in the area code rule.
  • Select or create a dialing rule if one does not exist.
  • Specify the area code.
  • Specify the prefix parameters.
  • Specify the action parameters.
In addition, you can organize, view, modify, and delete area code rules, if necessary.
About Dialing Rules
