About Dispatch Component
The Dispatch component determines the appropriate delivery method for all inbound and outbound messages. You can have up to four instances of this component.
Normalization Properties
The Dispatch component converts a destination number into a fully qualified number that would be meaningful to someone located anywhere in the world. For example, if a user in the United States sends a fax to 123-4567, the Dispatch component converts this number to +1-XXX-123-4567 whereby + represents the international access code identifier, 1 represents the international access code for the United States, XXX represents the area code of the destination number, and 123-4567 is the destination number.
After converting the destination number into a standard, fully qualified number, the Dispatch component applies normalization rules to the fully qualified number so that the Modem Server can dial the number correctly from its respective location. For example, if the destination number is local to the Modem Server, normalization rules remove the leading digits from the destination number so that the Modem Server dials the number as a local call.
The installation program created a set of default normalization rules that should be sufficient for Modem Servers in the United States. For Modem Servers in the United Kingdom, create a new set of normalization rules.
Creating a Normalization Rule
Modifying a Normalization Rule
About United States Country Code
