About WebApps Document Sets
Companies have different documents that are related to specific workflow processes. Administrators can set up the use of document sets for their process owners and contributors. Scan Reservations and Batch Routing Sheets are created by WebApps users based on the document sets configured and used for scanning and delivery of the documents. Document sets can be used in a variety of ways. See examples below.
  • HR New Hire Document Set – all documents related to the hiring process of a new employee
  • Legal Case Document Set – all documents related to a client’s legal matter
  • Loan Document Set – all documents related to a client’s loan application
  • Hospital Patient Document Set – all documents related to a patient’s care
Understanding the Document Sets workflow
Administrators create the rules, job properties, categories and form types associated with a particular document set using the Server Administrator. Document Sets is an internal label that can be renamed to be more descriptive and reflect your specific workflow process.
WebApps users select the categories and form types associated with a particular document set and capture the appropriate properties by creating Scan Reservations or Batch Routing Sheets.
Using the Scan Reservation or Batch Routing Sheets created, WebApps users scan the documents that are delivered by the server based on the workflow rule(s) established by the Administrator.
Note: Scan reservations are considered personal distributions. WebApps users cannot view or execute each other's personal distributions only their own at a device.
Before you begin
Prerequisites
Setup
Complete the following tasks after the installation, device, and group configurations are done.
  • Plan Document Set workflows which include the following:
    • Rules related to your workflows
    • Job properties related to form fields and types
    • Determine who will be creating scan reservations or batch routing sheets.
    • Determine who will be scanning documents at a device.
  • Set up Document Sets
    • Create a rule for your workflow.
    • Set up job properties for form fields and types.
    • Add the Document Sets application to a WebApps profile
    • Use default or modify actions
    • Add predefined form fields
    • Use default or add new properties
    • Create categories and form types
    • Choose a Batch Routing Sheet template
Setting up WebApps Document Sets
The Loan Document Set will be used as an example in the next series of steps for illustrative purposes only and may not reflect your specific workflow configuration. Form fields and form type properties can be used to uniquely identify the documents associated with a process.
Note: Document Sets is a flexible tool that can be used in a variety of ways to meet the requirements of your document workflow processes and can be as robust as you need it to be.
Loan Document Set at a Glance
In the Loan Document Set scenario shown above, the Administrator creates a Home Loan category and the following form types.
  • Mortgage Application
  • Credit Report
  • Employment Verification
  • Checking Savings Bank Statement
  • W2 Wages
Categories are created to organize the form types associated with a document set. Form types are placeholders that represent the forms that will be scanned at a device by the Device Client user. The forms are routed by the server based on the rules created by the Administrator. The Scan Reservations or Batch Routing Sheets created by the WebApps user contain the following distribution/destination information.
  • Document Set Category
  • Form Types
  • Form Fields - used to identify and classify the form types.
  • Form Field properties
  • Form Type properties
Properties are used to provide additional information about form fields and form types.
Using Document Sets for WebApps Users
Using Document Sets for Device Client Users
