About Group-specific Time Zones
As companies grow their presence domestically and internationally there is a need to show time zones specific to a group’s location on cover pages, fax top lines and email notifications. Administrators can enable group-specific time zones by using the Group > Location setting and Job > System TimeZoneName property. The time zone variables listed below can be used with configurations that include AccuRoute CloudFax and InterFAX.
Note: If you are planning a server upgrade, contact Technical Support for assistance if you want to use group-specific time zones. This feature only works on AccuRoute Server v5.0 and above.
Before you begin
Administrator must complete the following tasks.
  • Plan your groups and time zones appropriately.
  • Create or use current groups.
  • Apply the appropriate time zone location to your groups.
  • Create or update the cover pages, fax top lines, and email notifications with the following Date and Time Zone variables.
    • %:currentDate(,,$)%
    • %:currentTime(,,$)%
Note: The Time Zone variables are case-sensitive and must begin and end with the Percent symbol (%) as shown above.
See the following Help topics for more information.
Group-specific Time Zones at a Glance
Group-specific Time Zones Legend
Description
1. Group Properties dialog box
Use the Group Properties > Location setting to enable members of a specific group to use the time zone selected.
2. Job Properties > System > TimeZoneName
Used by the server to verify the appropriate Group > Location setting, and date and time zone variables are applied to specific groups and their workflow cover page, fax top line, and email notification templates.
Note: This happens behind the scenes and does not require any additional configuration.
Accessing Group-specific time zone settings
You can access the Group Properties > Location setting by using Configuration > Groups on the Server Administrator tree.
To access Groups
  2. Expand the Server Administrator tree, if necessary.
  3. Expand Configuration.
  4. Select Groups. The groups appear in the details pane.
  5. Select a group. The Group Properties dialog box appears.
  6. Specify or modify the Location setting as needed.
  7. Click OK.
Setting up Group-specific Time Zones
