About Server Dashboard
The Server Dashboard is a WebApps tool that Administrators can use to monitor the status of their server configuration in a live environment. It monitors and displays a server’s services, connectors, queues, compose engine states and more in a color-coded format. Administrators can customize the Server Dashboard view by modifying default test criteria or creating new test criteria specific to their server configurations. In addition, WebApps users typically fulfilling an Administrator or Power User role can view the Server Dashboard based on specific group permissions granted while other groups cannot.
What is monitored
Expand to view more information.
Before you begin
The following installations are required and must be completed before you can set up the Server Dashboard.
  • Server
  • Server Monitor
  • WebApps
See  the Server and Client Installation Guides for more information.
Note: Device Client installation with device simulation is optional and can be configured to work with the Server Dashboard. Contact Technical Support for further assistance.
Setting up Server Dashboard
About Server Dashboard Telco Channel Status
