About WebApps Device Address Book
New devices may require the latest address book to do its job. Administrators can update a device’s address book by simply transferring the address book from an existing device to another. Setup is needed in the Server Administrator. The transfer of the address book is done in WebApps. Administrators search for the existing device by serial number, identify the new device, and complete the transfer of the address book.
Note: Device users will not be able to access the address book on the device used to transfer the address book from if you are planning on keeping the device active.
Before you begin
  • Add Device Address Book Application.
    • Add the Search action.
  • Enable Enhanced Faxing and Address Book Support.
  • Transfer the Address Book.
Adding the Device Address Book application
You can add the Device Address Book application to a WebApps Profile by using Configuration > WebApps in the Server Administrator.
To add the Device Address Book application
  2. Expand Configuration.
  3. Select WebApps.
  4. Select the Default profile or a different profile, if necessary. The Profile Properties dialog box appears.
  5. Select the Applications tab.
See the Profile Properties > Applications dialog box example below.
  1. Select the Add button. The Applications shortcut menu appears.
  2. Select Administration > Device Address Book.
  3. Select OK on the Device Address Book Application Properties dialog box.
  4. Select OK on the Profile Properties dialog box.
About WebApps
About Devices
