About WebApps DMS Document Profiling
Document Profiling also known as Document Tagging is a feature that helps users access and retrieve documents stored in a document management system (DMS). A document profile specifies the DMS location, format, and metadata for delivery, identification, and searching purposes.
WebApps supports DMS document profiling. In addition, the Desktop Client is integrated with WebApps and is used for configuring DMS document profiling. Users will be able to create DMS profile records when creating distributions and using MyFiles.
This integration only supports the following document management systems.
  • DM
  • DocuShare
  • FileBound
  • FileShare
  • iManage
  • OpenDocs
  • RecordsManager (previously known as Trim)
  • SharePoint
  • Worldox
Note: It does not support cloud-based document management systems.
The Desktop Client can be configured to integrate with document management systems and other specialized applications that extend the functionality of pre-existing document storage and retrieval methods. WebApps users will be creating profile records that contain destination, document format, and metadata information for the DMS via the Desktop Client.
Before you begin
  • Obtain and activate the Desktop Client license, if necessary. Contact your Account Manager and see Activating a license for more information.
Note: The WebApps Client is part of the standard server installation and does not require a license.
Note: WebApps is installed on the server or another remote IIS system. The Desktop Client is not installed on the server, but must be installed on each user’s desktop.
  • Configure the Desktop and WebApps .
Desktop Client WebApps DMS Document Profiling Configuration Checklist
This checklist highlights some important configuration requirements that Administrators and WebApps users must do to set up DMS document profiling after the Desktop and WebApps are installed.
Creating a DMS Document Profile
